Question: setting up "my network places" for virtual machines.
  1. #1
    FACE Guest
    Host: Win XP pro
    I have a virtual machines that has small traffic between it and the host
    machine.
    I do not want "additions" for a shared folder.
    I want to set it up as a network drive.
    So far as i see, I need to set it up in "My network Places".
    I have no idea how to describe it.
    The "view examples" on the description page is an empty hyperlink.
    Any help here?
    FACE
  2. #2
    Bob Campbell Guest
    Re: Question: setting up "my network places" for virtual machines.
    "FACE" <AFaceInTheCrowd@xxxxxx> wrote in message
    news:loteg4tta060l9t6c239f5791nobha8ud5@xxxxxx
    > Host: Win XP pro
    > machine.
    Well, the Additions have other benefits, besides shared folders. Mouse
    improvements, faster screen in the guest (video card enhancements), overall
    better performance of the guest. The guest runs MUCH better after the
    additions have been installed.
    Share the drive in the host. Right click it and choose Share. In the
    guest, map a drive letter to the shared host drive. The path will be
    \\host computer name\shared drive name".
    Doing it this way is faster and more reliable than the "Shared Folders".
  3. #3
    Bo Berglund Guest
    On Tue, 28 Oct 2008 17:01:10 -0400, FACE <AFaceInTheCrowd@xxxxxx>
    wrote:
    >Host: Win XP pro
    >machine.
    >Any help here?
    >FACE
    You can do what you want directly on the command prompt on each
    machine. We use this method in batch scripts in the startup folder on
    machines we need to use specific shared folders.
    From the top of my head:
    Start on the host by creating a folder and then sharing it on the
    network:
    c:\>mkdir c:\data\sharedfolder
    c:\>net share myshare=c:\data\sharedfolder /unlimited
    Then on the guest connect to that share as drive letter W:
    c:\>net use W: \\<hostpcname>\myshare /persistent:yes
    For this to work the user account on the guest that performs this
    operation must also exist on the host as a local user with the same
    password. It is possible to also define the user account on the host
    to use directly on the command line:
    c:\>net use W: \\<hostpcname>\myshare <password> /user:<accountname>
    /persistent:yes
    If you want write access (default is read only) then you need to go to
    the host and use Windows Explorer and rightclick the shared folder and
    select properties/security and then for the user's entry allow write
    access (or full control).
    Bo Berglund (Sweden)
  4. #4
    FACE Guest
    On Tue, 28 Oct 2008 17:17:03 -0400, in microsoft.public.virtualpc, "Bob
    Thanks. I needed the example.
    FACE
Question: setting up "my network places" for virtual machines. problems?
Unused icons in "My Network Places." PVR Vista networking & sharing 0 27 Mar 2009
Vista "Network" places Does not Display Anything...? TamaDrumz76 Network & Sharing 9 11 Jan 2009
Change location of "My Virtual Machines" Magnusb Virtual PC 0 16 Oct 2008
Vista's equivalent of "My Network places"? Michael Moser Vista networking & sharing 2 31 Aug 2008
What happened to "network places" rich Vista General 10 20 Dec 2006
