| | RE: Normal to report the wrong CPU speed in a VM? Quote: > I noticed that while Vista properly reports the host CPU speed on its System > page (3.00Ghz, 2.99Ghz), the guest System page (also running Vista) reports: > 3.00GHz, 13MHz. So I take that to mean that guest Vista thinks the CPU is > running at 13MHz. Whose bug is this, VPC 2007's or Vista's? > > Thanks http://blogs.technet.com/perfguru/ar...-boot-ini.aspx Try editing the boot.ini file and adding the switch to the end. /usepmtimer Then reboot. Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com |
| Wrong CPU speed, with Q6600 | Vista performance & maintenance | |||
| CPU showing wrong speed on vista | Vista hardware & devices | |||
| Report Report !! Biggest Vista piracy website found !!! | Vista General | |||
| Bug report : wrong size of pagefile displayed in the task manager | Vista General | |||
| Wrong processor speed detected | Vista hardware & devices | |||
