Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Scanner does not work for W98 Virtual PC in WinXP
Old 11-03-2008   #1 (permalink)
chasW98
In the past I have used a dual boot system for W98 and Wxp.
My Visioneer One Touch scanner works with W98 (no driver was developed for
XP).
I decided to install W98 as a virtual PC in Win XP Pro.
I cannot get the scanner to work.
If the scanner is powered on when I start XP I get a hardware error because
Visioneer only developed a driver for W98.
I have tried to connect/power on the scanner when I am in W98 virtual PC but
that does not work either.
In order to use peripheral equipment is it necessary for Win XP to have a
driver for the specific peripheral equipment?
Do I have to go back to dual boot to use the scanner?
Can't install Virtual Machines Additions on VPC 2007 SP1 + WinXP S Virtual PC
WinXP Guest under WinXP Host VPC2007 Sound missing Virtual PC
Scanner does not work Vista installation & setup
Scanner does not work Vista General
Add space in Virtual PC to upgrade WinXP to Vista? Vista installation & setup
