Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - XP Pro 32bit on 64bit Vista running VPC 2007
Old 11-17-2008   #1 (permalink)
ThomasAJ
I want to upgrade my hardware to a 64bit Vista machine running Microsoft
Virtual PC 2007. Can I run my old 32bit XP Pro OS on it. I would install the
XP onto the Vista using Acronis.
Regards
Tom
I have dual boot PC [VISTA 32BIT & 64BIT]---problems only in 64bit vista drivers Drivers
Running Vista 32bit, recovery 64bit???? Vista installation & setup
In a 64bit PC may make 4 partitions vista 32bit, vista 64bit, and ... Virtual PC
64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions General Discussion
switching from 64bit to 32bit now then back to 64bit later Vista installation & setup
