| Guest | How does Memory allocation in VPC 2007 64bit on 64bit OS work? I am considering building a new system and I'm trying to put together specs. I'm inclined to build a system with Intel Quad Core with either XP Pro 64 or Vista 64 and 8GB RAM. I want to run multiple VMs in VPC. Since VPC 2007 has a 64 bit version, will it access all available memory for allocation to guest OSs? For example, can I put 8GB RAM in the host machine, run 4-32bit guest OSs with 1.5GB allocated to each? I know each 32bit OS could use the 1.5GB of memory, but that would hinge of VPC 2007 using a total of 6GB of RAM to distribute out to the VM's. Will this work? I have some stuff that could really benefit from giving the guest OS's at least 1GB of RAM and I would like to have them all running at times, while still allowing a good bit of RAM to stay open to the host OS. The only way I can see how to do that is with more than 4GB of RAM - thus the whole 64 bit route. Thanks in adavance! Andrew |
| Guest | Re: How does Memory allocation in VPC 2007 64bit on 64bit OS work? On Sat, 22 Nov 2008 13:38:24 -0800 (PST), Andrew Meador <andrew@xxxxxx> wrote: Quote: > I am considering building a new system and I'm trying to put >together specs. I'm inclined to build a system with Intel Quad Core >with either XP Pro 64 or Vista 64 and 8GB RAM. I want to run multiple >VMs in VPC. Since VPC 2007 has a 64 bit version, will it access all >available memory for allocation to guest OSs? For example, can I put >8GB RAM in the host machine, run 4-32bit guest OSs with 1.5GB >allocated to each? I know each 32bit OS could use the 1.5GB of memory, >but that would hinge of VPC 2007 using a total of 6GB of RAM to >distribute out to the VM's. Will this work? I have some stuff that >could really benefit from giving the guest OS's at least 1GB of RAM >and I would like to have them all running at times, while still >allowing a good bit of RAM to stay open to the host OS. The only way I >can see how to do that is with more than 4GB of RAM - thus the whole >64 bit route. > > Thanks in adavance! > >Andrew -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| 64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions | General Discussion | |||
Unable to install 64bit NVidia drivers on Vista 64bit | Drivers | |||
| Vista Premium 64bit to Ultimate 64bit Upgrade Fails | Vista installation & setup | |||
| Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media | Vista installation & setup | |||
| Usb memory stcik dosent work on Windows vista home premium 64bit | Vista hardware & devices | |||
