| 32 | Resize Virtual disk - Pleasee Help! Hello! What is the way to resize a fixed virtual hd? Any 3 Party tool? Thanks! |
| windows xp | Re: Resize Virtual disk - Pleasee Help! Why not anyone answer the question? Windows 7 contains a new feature that allows you to resize the VHD in the disk management tool. Or you can use some third party software to resize virtual disk. How to resize virtual hard disk without data loss? |
| Virtual PC 2007 with Windows ME - Where to place virtual disk | Vista General | |||
| RE: How to resize a virtual disk? | Virtual PC | |||
| Convert VMWare virtual disk to Virtual Server disk (VHD) | Virtual Server | |||
| MS Virtual PC 2007 - virtual hard disk | Vista installation & setup | |||
| disk managment error - Unable to Connect to Virtual Disk Service | Vista performance & maintenance | |||
