Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - DDE Client problems
Old 11-27-2008   #1 (permalink)
majic79
DDE Client problems
I'm having some trouble with setting up a DDE client in a Windows 2000 SP4
Virtual Machine. The Host is XP SP3.
When I connect (guest) to a DDE Server (same guest) it seems to connect for
a few seconds before dropping off. When I connect Guest to Host, again the
same thing.
Has anyone had similar experiences or can suggest a resolution? We thought
that the virtual environment would allow us to support legacy
software/systems without having to maintain legacy hardware.
If more details are required, then I'll gladly supply them
Old 11-27-2008   #2 (permalink)
majic79
RE: DDE Client problems
Just to add, Host PC is running Virtual PC 2007 SP1, both (Real and Virtual)
PC's have the same server installed (RSLinx) when I use DDESpy to look at the
output, this is the information I get back (as well as all the queries to the
rest of the top level windows on the OS)
Host PC:
Task:0x1640 Time:3498656 hwndTo=0x100b4 Message(Sent)=Initiate:
hwndFrom=0x180368, App=0xc05b("RSLINX")
Topic=0xc05c("CLOGIX")
Task:0x528, Time:3498671, String Handle Incremented: c003(CLOGIX)
Task:0x528 Time:3498671 Callback:
Type=Connect, fmt=0x0("?"), hConv=0x0, hsz1=0xc000("CLOGIX")
hsz2=0xc001("RSLINX"), hData=0x0, dwData1=0x0, dwData2=0x0
return=0x1
Task:0x528 Time:3498687 hwndTo=0x180368 Message(Sent)=Ack:
hwndFrom=0x1c02ca, App=0xc05b("RSLINX")status=c05b(fAck fBusy )
Topic=Item=0xc05c("CLOGIX")
Task:0x528, Time:3498687, String Handle Incremented: c003(CLOGIX)
Task:0x528, Time:3498703, String Handle Incremented: c001(RSLINX)
Task:0x528 Time:3498703 Callback:
Type=Connect_confirm, fmt=0x0("?"), hConv=0x6000500, hsz1=0xc001("CLOGIX")
hsz2=0xc000("RSLINX"), hData=0x0, dwData1=0x0, dwData2=0x0
return=0x0
Guest PC:
Task:0x26c Time:2199903 hwndTo=0x10046 Message(Sent)=Initiate:
hwndFrom=0x80054, App=0xc02e("RSLINX")
Topic=0xc02d("CLOGIX")
Task:0x398 Time:2199903 Callback:
return=0x0
Old 11-27-2008   #3 (permalink)
Bo Berglund
Re: DDE Client problems
On Thu, 27 Nov 2008 01:00:03 -0800, majic79
>same thing.
Are you talking about DDE between two applications running in the
virtual machine?
Or are you trying to establish DDE connectivity between an application
running on the host and one running in the virtual machine?
It is not clear to me what you are trying to accomplish....
Bo Berglund (Sweden)
Old 11-27-2008   #4 (permalink)
majic79
Initially I'm trying to connect the DDE Client on the Guest to the DDE Server
on the Guest. I'm also wanting to go from Guest to Host across the Loopback
adapter, but that can wait - I'll settle for getting the Guest DDE Client to
Guest DDE Server working!
> >same thing.
> virtual machine?
ultimate: problems/default email client.. Vista General
Problems using IE7 with Explorer as FTP Client Vista General
Problems Receiving Mail in POP3 Client Browsers & Mail
Problems Receiving Mail in POP3 Client Microsoft Office
Problems with IE7 and Explorer as FTP client Vista security
