| | Disk space problem I have WinXP SP2 installed on a Virtual PC 2007 virtual machine. On C: (primary partition; basic) I have 605 Mb free disk space which is not sufficient for (amongst other things), to install SP3. I've tried: 1. Adding another virtual volume through Virtual PC, however, within Disk Management (Start > Control Panel > Computer Management > Disk Management), the option for spanned disk was disabled, when converting the new disk (dynamic disk) I had just added. Any idea why? So this was unsuccessful and I tried solution 2... 2. Adding the new disk, however, instead of assigning it a new drive letter, I mounted the volume within c:\disk02. SP 3 installation program is still complaining about low disk space. Disk space displayed within C: (right click on the hard disk > Properties > Checking out the free disk space), now shows as 268 Mb, which is low. Any ideas how to: 1. add disk space so it appears as additional disk space within C: ? 2. hack my way around so I can install SP3 ? Jon |
| | Re: Disk space problem On Sun, 30 Nov 2008 01:04:02 -0800, Jon <Jon@xxxxxx> wrote: Quote: >I have WinXP SP2 installed on a Virtual PC 2007 virtual machine. > >On C: (primary partition; basic) I have 605 Mb free disk space which is not >sufficient for (amongst other things), to install SP3. Quote: >I've tried: >1. Adding another virtual volume through Virtual PC, however, within Disk >Management (Start > Control Panel > Computer Management > Disk Management), >the option for spanned disk was disabled, when converting the new disk >(dynamic disk) I had just added. Any idea why? So this was unsuccessful and I >tried solution >2... 2. Adding the new disk, however, instead of assigning it a new drive >letter, I mounted the volume within c:\disk02. Quote: >SP 3 installation program is >still complaining about low disk space. Disk space displayed within C: (right >click on the hard disk > Properties > Checking out the free disk space), now >shows as 268 Mb, which is low. > >Any ideas how to: > >1. add disk space so it appears as additional disk space within C: ? hold the data then you are in exactly the same situation as if you had a physical hard drive you have outgrown! You need to get yourself a new bigger drive and transfer the system into that using a disk imaging program. I would do the following: - Use VPC2007 Virtual Disk Wizard to create a new *dynamically expanding* virtual disk of sufficient size (max is 130 Gb). It will start out very small (35 kb) *.VHD file on your host system, but you need to put it on a host drive with sufficient free space to grow to the expected data size in your guest. - Shut down your guest completely and commit any undo disk contents. - Then in the properties of the guest add the newly created virtual disk as disk #2. - Then start the guest again - Go to disk manager inside the guest and initialize the new drive. - Then inside the guest go to Acronis webpage and download the trial of Aconis Workstation. Install it in the guest. - Start Acronis and use it to clone the existing C drive to the new secondary drive. You need to select this function from the menu, none of the shortcuts on the form are what you want. - Then Acronis will reboot your guest and you will get to its transfer page where the actual transfer will be done. - After this you shut down the guest completely again and go into the guest settings in the VPC2007 console. Here you change the hard disk assignments by pointing disk 1 to the new drive and setting disk 2 to none. This decouples your old drive from the guest operating system. - Then restart your guest. It will now have a new bigger drive and you can do whatever you planned to do. - Uninstall the Acronis trial, because it is no longer needed and it will only last for 15 days anyway. -- Bo Berglund (Sweden) |
| No free disk space error even though there is enough disk space on Windows Vista x64 | Vista installation & setup | |||
Low Disk Space Problem | General Discussion | |||
| Low Disk Space Problem | Vista performance & maintenance | |||
| Low Disk space problem | Vista performance & maintenance | |||
| Low disk space free problem | Vista General | |||
