| | network problem; ip address conflict When I start virtual machine (winxp home) I get a message on the host saying: "there is an IP address conflict with another system on the network". It later says this on the guest, too. I already tried disabling my firewall (I have Symantec Endpoint protection), and tried (but failed) to change the IP address on the guest manually (What I got was "the static IP address you have assigned is being used by another system on the network" (message is not exact, will try to get exact message in next response)). I don't know how this happened, because it worked before and I don't know of doing any change, such as installing a program or changing network adapters. Thanks in advance. |
| | Re: network problem; ip address conflict "penguin" <penguin@xxxxxx> wrote in message news:F942CED2-C69A-4267-A167-3BB9E7A2B3C9@xxxxxx Quote: > When I start virtual machine (winxp home) I get a message on the host > saying: "there is an IP address conflict with another system on the > network". > It later says this on the guest, too. I already tried disabling my > firewall > (I have Symantec Endpoint protection), and tried (but failed) to change > the > IP address on the guest manually (What I got was "the static IP address > you > have assigned is being used by another system on the network" (message is > not > exact, will try to get exact message in next response)). > > I don't know how this happened, because it worked before and I don't know > of > doing any change, such as installing a program or changing network > adapters. network is configured. Assuming you have a router (or some other device acting as a DHCP server), make sure that your virtual machine is configured to receive an IP address automatically, not manually... -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: network problem; ip address conflict Very, very strange. It suddenly works!?! That's weird, because all I did was wake my pc from standby (although I did reboots when I saw this error). Anyways, what I was going to say was when I used cmd.exe to do this command "ipconfig /renew" it came up with the following error: "The DHCP client has obtained an ip address that is alread in use on the network. the local interface will be disabled until the DHCP client can obtain a new address." Also, when trying to repair (on guest) it said windows could not repair your connection because it couldn't renew my ip address. I'm still confused and don't know why it works now. But hopefully I won't encounter this again. Thanks for the prompt response. "Mark Rae [MVP]" wrote: Quote: > Firstly, you should be able to fix this fairly easily, depending on how your > network is configured. Assuming you have a router (or some other device > acting as a DHCP server), make sure that your virtual machine is configured > to receive an IP address automatically, not manually... > > > -- > Mark Rae > ASP.NET MVP > http://www.markrae.net > > |
| | Re: network problem; ip address conflict "penguin" <penguin@xxxxxx> wrote in message news:F942CED2-C69A-4267-A167-3BB9E7A2B3C9@xxxxxx Quote: > When I start virtual machine (winxp home) I get a message on the host > saying: "there is an IP address conflict with another system on the > network". > It later says this on the guest, too. I already tried disabling my > firewall > (I have Symantec Endpoint protection), and tried (but failed) to change > the > IP address on the guest manually (What I got was "the static IP address > you > have assigned is being used by another system on the network" (message is > not > exact, will try to get exact message in next response)). > > I don't know how this happened, because it worked before and I don't know > of > doing any change, such as installing a program or changing network > adapters. > > Thanks in advance. problem repeatedly for awhile suddenly and seemingly out of nowhere. The one reliable way to fix it was to unplug the router and modem and shut down all physical computers on the network. Wait a few minutes and then boot the physical computers as close together as possible. When the desktop appears plug in the modem, when it synchs then plugin the router. This forces the router to assign new IP addresses to each computer. I then would start all my virtual machines and make sure each machine had its own address. I have two physical computers and several virtual machines on one of the physical computers. Sometimes, the IP address conflict was between the two physical computers, but other times it was between a virtual computer and the host physical computer. There are other ways to fix the problem but none worked consistently for me and actually usually were a waste of time because they didn't work and I still had to force the router to reassign new addresses. I never learned what caused this sudden problem. After a few weeks, it disappeared as suddenly as it had appeared and I haven't had the problem since but I read that this problem can appear suddenly, disappear suddenly, and then reappear months, years later so I might have it again sometime. This started the first time after I had my older physical computer shutdown for about 24 hours (usually they are both on 24/7) and when I booted it after being shutdown I saw, almost immediately on the newer XP computer, the notice in the systray about an IP address conflict. I think the router assigned the address the older 98SE computer usually uses to the XP computer because it was available for 24 hours when the older computer was shut down. The conflicts between the virtual machines and either one of the physical machines, or between two virtual machines, were really puzzling and nothing I tried (after Googling the problem) fixed it reliably except the irritating, time consuming method I mentioned above. It did seem though that if I did not use a virtual machine for several days then it would have this conflict when I started it but I don't think not using a virtual machine for days or a week or longer should have anything to do with this because before I had this problem many times I didn't use a virtual machine for days or a week or so and had no ip address conflicts. So, the reason for this sudden problem (and its subsequent sudden disappearance after annoying me for about a month) remain a mystery. |
| | Re: network problem; ip address conflict sorry for the last 2 posts. I wish there was a way to edit your post. I'm still having problems. I can visit a few sites, but they a) take a long time to load, or b) don't load at all (cannot connect to server). Also, downloads are slow (at a rate of about 4 KB/Sec). I'm not a network guy with TCP, IP, DHCP, Subnet mask, and all that stuff, so I'm completely clueless on what's going on. |
| | #6 (permalink) |
| | Re: network problem; ip address conflict ---> Quote: > "penguin" <penguin@xxxxxx> wrote in message > news:F942CED2-C69A-4267-A167-3BB9E7A2B3C9@xxxxxx Quote: >> When I start virtual machine (winxp home) I get a message on the host >> saying: "there is an IP address conflict with another system on the >> network". >> It later says this on the guest, too. I already tried disabling my >> firewall >> (I have Symantec Endpoint protection), and tried (but failed) to change >> the >> IP address on the guest manually (What I got was "the static IP address >> you >> have assigned is being used by another system on the network" (message is >> not >> exact, will try to get exact message in next response)). >> >> I don't know how this happened, because it worked before and I don't know >> of >> doing any change, such as installing a program or changing network >> adapters. >> >> Thanks in advance. > I assume you have a router assigning the addresses automatically. I had this > problem repeatedly for awhile suddenly and seemingly out of nowhere. The one > reliable way to fix it was to unplug the router and modem and shut down all > physical computers on the network. Wait a few minutes and then boot the > physical computers as close together as possible. When the desktop appears > plug in the modem, when it synchs then plugin the router. This forces the > router to assign new IP addresses to each computer. I then would start all > my virtual machines and make sure each machine had its own address. I have > two physical computers and several virtual machines on one of the physical > computers. Sometimes, the IP address conflict was between the two physical > computers, but other times it was between a virtual computer and the host > physical computer. There are other ways to fix the problem but none worked > consistently for me and actually usually were a waste of time because they > didn't work and I still had to force the router to reassign new addresses. > > I never learned what caused this sudden problem. After a few weeks, it > disappeared as suddenly as it had appeared and I haven't had the problem > since but I read that this problem can appear suddenly, disappear suddenly, > and then reappear months, years later so I might have it again sometime. > This started the first time after I had my older physical computer shutdown > for about 24 hours (usually they are both on 24/7) and when I booted it > after being shutdown I saw, almost immediately on the newer XP computer, the > notice in the systray about an IP address conflict. I think the router > assigned the address the older 98SE computer usually uses to the XP computer > because it was available for 24 hours when the older computer was shut down. > > The conflicts between the virtual machines and either one of the physical > machines, or between two virtual machines, were really puzzling and nothing > I tried (after Googling the problem) fixed it reliably except the > irritating, time consuming method I mentioned above. It did seem though > that if I did not use a virtual machine for several days then it would have > this conflict when I started it but I don't think not using a virtual > machine for days or a week or longer should have anything to do with this > because before I had this problem many times I didn't use a virtual machine > for days or a week or so and had no ip address conflicts. So, the reason for > this sudden problem (and its subsequent sudden disappearance after annoying > me for about a month) remain a mystery. > > If this happens again, check your router for a DHCP client table. My router (Linksys) began issuing double IP addresses quite a few times and my investigation showed that the DHCP client table had double entries in it for the same machine, but different IP address. But also there were the same IP addresses for two or more machines. In my network, I start and shutdown machines at irregular intervals and I think this table was getting filled up with bad entries. There was a button the table page of the router that said, in effect, "Clear the table". When I did that and restarted the router all the operating computers were then told to 'ipconfig /renew' and they all got new IP addresses - that didn't conflict. I would have to clear the table and restart everything about once a month. My final solution to this was to turn off DCHP and assign static addresses on my LAN. It's a pain to do so but since I use two of them as hosts for gaming having the fixed IP addresses helps in boring a hole through the router firewall. GP |
| | #7 (permalink) |
| | Re: network problem; ip address conflict The only problem is, I'm not connected to a router! (Until Jan. 15, when I cancel my dsl and wirelessly connect to my netgear router, connected to a cable modem) Shared networking seems to work for me. But is my host PC still safe (with shared networking) if my guest gets infected (not sharing any files)? "Grand_Poobah" wrote: Quote: > ---> Quote: > > "penguin" <penguin@xxxxxx> wrote in message > > news:F942CED2-C69A-4267-A167-3BB9E7A2B3C9@xxxxxx Quote: > >> When I start virtual machine (winxp home) I get a message on the host > >> saying: "there is an IP address conflict with another system on the > >> network". > >> It later says this on the guest, too. I already tried disabling my > >> firewall > >> (I have Symantec Endpoint protection), and tried (but failed) to change > >> the > >> IP address on the guest manually (What I got was "the static IP address > >> you > >> have assigned is being used by another system on the network" (message is > >> not > >> exact, will try to get exact message in next response)). > >> > >> I don't know how this happened, because it worked before and I don't know > >> of > >> doing any change, such as installing a program or changing network > >> adapters. > >> > >> Thanks in advance. > > I assume you have a router assigning the addresses automatically. I had this > > problem repeatedly for awhile suddenly and seemingly out of nowhere. The one > > reliable way to fix it was to unplug the router and modem and shut down all > > physical computers on the network. Wait a few minutes and then boot the > > physical computers as close together as possible. When the desktop appears > > plug in the modem, when it synchs then plugin the router. This forces the > > router to assign new IP addresses to each computer. I then would start all > > my virtual machines and make sure each machine had its own address. I have > > two physical computers and several virtual machines on one of the physical > > computers. Sometimes, the IP address conflict was between the two physical > > computers, but other times it was between a virtual computer and the host > > physical computer. There are other ways to fix the problem but none worked > > consistently for me and actually usually were a waste of time because they > > didn't work and I still had to force the router to reassign new addresses. > > > > I never learned what caused this sudden problem. After a few weeks, it > > disappeared as suddenly as it had appeared and I haven't had the problem > > since but I read that this problem can appear suddenly, disappear suddenly, > > and then reappear months, years later so I might have it again sometime. > > This started the first time after I had my older physical computer shutdown > > for about 24 hours (usually they are both on 24/7) and when I booted it > > after being shutdown I saw, almost immediately on the newer XP computer, the > > notice in the systray about an IP address conflict. I think the router > > assigned the address the older 98SE computer usually uses to the XP computer > > because it was available for 24 hours when the older computer was shut down. > > > > The conflicts between the virtual machines and either one of the physical > > machines, or between two virtual machines, were really puzzling and nothing > > I tried (after Googling the problem) fixed it reliably except the > > irritating, time consuming method I mentioned above. It did seem though > > that if I did not use a virtual machine for several days then it would have > > this conflict when I started it but I don't think not using a virtual > > machine for days or a week or longer should have anything to do with this > > because before I had this problem many times I didn't use a virtual machine > > for days or a week or so and had no ip address conflicts. So, the reason for > > this sudden problem (and its subsequent sudden disappearance after annoying > > me for about a month) remain a mystery. > > > > > Penguin & Melelina: > > If this happens again, check your router for a DHCP client table. My > router (Linksys) began issuing double IP addresses quite a few times and > my investigation showed that the DHCP client table had double entries in > it for the same machine, but different IP address. But also there were > the same IP addresses for two or more machines. > > In my network, I start and shutdown machines at irregular intervals and > I think this table was getting filled up with bad entries. There was a > button the table page of the router that said, in effect, "Clear the > table". When I did that and restarted the router all the operating > computers were then told to 'ipconfig /renew' and they all got new IP > addresses - that didn't conflict. > > I would have to clear the table and restart everything about once a month. > > My final solution to this was to turn off DCHP and assign static > addresses on my LAN. It's a pain to do so but since I use two of them > as hosts for gaming having the fixed IP addresses helps in boring a hole > through the router firewall. > > GP > |
| | #8 (permalink) |
| | Re: network problem; ip address conflict "penguin" <penguin@xxxxxx> wrote in message news D3E1EE2-AF26-498E-9865-71546E9809F1@xxxxxxQuote: > Shared networking seems to work for me. But is my host PC still safe (with > shared networking) if my guest gets infected (not sharing any files)? machine as identical in every way to a physical machine. The software installed on it (both OS and applications) doesn't know that it's running on a virtual machine - it has no need to know that... Your guest needs to be protected against malware just as much as every other machine (physical or virtual) on your network: http://vpc.visualwin.com/ngfaq.aspx#17 -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #9 (permalink) |
| | Re: network problem; ip address conflict Okay, because I thought shared networking means connecting your PC to another PC which has access to the internet. (Since I've never did this, I don't know if the two computers can communicate, and any contagious virus on any PC would be able to replicate on the other PC) "Mark Rae [MVP]" wrote: Quote: > "penguin" <penguin@xxxxxx> wrote in message > news D3E1EE2-AF26-498E-9865-71546E9809F1@xxxxxx> Quote: > > Shared networking seems to work for me. But is my host PC still safe (with > > shared networking) if my guest gets infected (not sharing any files)? > The thing here, as with 99% of VPC questions, is to consider the virtual > machine as identical in every way to a physical machine. The software > installed on it (both OS and applications) doesn't know that it's running on > a virtual machine - it has no need to know that... > > Your guest needs to be protected against malware just as much as every other > machine (physical or virtual) on your network: > http://vpc.visualwin.com/ngfaq.aspx#17 > > > -- > Mark Rae > ASP.NET MVP > http://www.markrae.net > > |
| Network 'Identifying' Difficulty with Bluetooth MS Driver(s)--Conflict? Vista 64-bit Ultimate | Vista networking & sharing | |||
| IP Address conflict with a Virtual Server | Virtual Server | |||
| IP Conflict Preventing Network Access | Vista networking & sharing | |||
| IP address conflict | Vista networking & sharing | |||
| Network/Internet Conflict | Vista General | |||
