| | How to adjust screen resolution of guest operating system xp Hi, I have installed xp on vista home 64 using virtual pc 2007. can anybody help how to get fullscreen mode I am unable to do it as it is prompting the host resolution is not compatible. |
| | Re: How to adjust screen resolution of guest operating system xp "sekhar reddy" <sekhar reddy@xxxxxx> wrote in message news A7B1F23-B86E-4915-87CE-F060CD0BD464@xxxxxxQuote: > Hi, > > I have installed xp on vista home 64 using virtual pc 2007. can anybody > help > how to get fullscreen mode I am unable to do it as it is prompting the > host > resolution is not compatible. > > The settings for the virtual machine has an entry for display one of which is allow any resolution, try that. -- Alan Cameron |
| Virtual Guest reboots Host Operating System | Virtual PC | |||
| Unexpected shut down of the guest operating system. | Virtual Server | |||
| Guest Operating System will not hold onto CD ROM Drive | Virtual Server | |||
| Getting Guest Operating System Name | Virtual Server | |||
| Adjust my resolution... | Vista hardware & devices | |||
