| | can not start my virtual machine Hi, I have installed virtual pc2007 on xp host. I have copied the *.vhd and*.vmc on a share share of server2003. So I always have the access to a clean install. During my last add on of a new virtual server, vpc keep on looping and shuting down. Here is the error log. The description for Event ID ( 1001 ) in Source ( Microsoft Virtual PC 2007 ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: 812090781. Does anyone know how to fix this problem? Or what is causing it? Thank you -- A+/MCP |
| error: Virtual PC could not open the Virtual Machine Network Servicesdriver | Virtual PC | |||
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 | Virtual Server | |||
| Unable to install Virtual Guest Services on virtual machine | Virtual Server | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
