| | Copied Virtual Hard disk does not work I have copied my Virtual Hard disk to an extern USB drive, when i try to start the OS on the Virtual disk I get the following error: Windows could not start because the following file is missing or corrupt: <Windows root>\system32\ntoskrnl.exe. Please re-install a copy of the above file I have copied both the vhd and vmc files. I have tried all kind of combinations like creatin a new vmc file, reusing the existing one but nothing seems to work. One difference I am seeing between the original vhd file and the copied one is the size, somehow the size of the copied file is much smaller. Is it possible that the file somehow gets compressed on copying? Any help will be greatly appreciated. |
| | Re: Copied Virtual Hard disk does not work "Bofors" <bofors@xxxxxx> wrote in message news:ukyzZ2waJHA.5788@xxxxxx Quote: > I have copied my Virtual Hard disk to an extern USB drive, when i try to > start the OS on the Virtual disk I get the following error: > > Windows could not start because the following file is missing or corrupt: > <Windows root>\system32\ntoskrnl.exe. > Please re-install a copy of the above file > > I have copied both the vhd and vmc files. I have tried all kind of > combinations like creatin a new vmc file, reusing the existing one but > nothing seems to work. One difference I am seeing between the original vhd > file and the copied one is the size, somehow the size of the copied file > is much smaller. Is it possible that the file somehow gets compressed on > copying? > > Any help will be greatly appreciated. > it and making a fresh copy from your external drive? |
| | Re: Copied Virtual Hard disk does not work Ok. I will just start all over again. Copy the working copy to external disk and try again but I don't think that's the case because I have a few other virtual hard disk images and none of them work either. Thanks "Bill Grant" <not.available@xxxxxx> wrote in message news:eIyd8$waJHA.4520@xxxxxx Quote: > > > "Bofors" <bofors@xxxxxx> wrote in message > news:ukyzZ2waJHA.5788@xxxxxx Quote: >> I have copied my Virtual Hard disk to an extern USB drive, when i try to >> start the OS on the Virtual disk I get the following error: >> >> Windows could not start because the following file is missing or corrupt: >> <Windows root>\system32\ntoskrnl.exe. >> Please re-install a copy of the above file >> >> I have copied both the vhd and vmc files. I have tried all kind of >> combinations like creatin a new vmc file, reusing the existing one but >> nothing seems to work. One difference I am seeing between the original >> vhd file and the copied one is the size, somehow the size of the copied >> file is much smaller. Is it possible that the file somehow gets >> compressed on copying? >> >> Any help will be greatly appreciated. >> > I would say that you have a corrupt .vhd file. Have you tried deleting > it and making a fresh copy from your external drive? |
| | Re: Copied Virtual Hard disk does not work Copied the vhd file to external drive and still the same problem. When I try to run the VPC with vhd on the external drive I get the following error: Windows could not start becasue the following file is missing or corrupt: \Windows\System32\config\system You can attempt to repair this file by starting Windows setup using the original Setup CD-ROM ....... If I copy this vhd file to my main hard drive I get the other mentioned in the original post. Host OS is Windows XP, guest OS is Windows Server 2003 and I am running Virtual PC 2007. This problem is driving me nuts. Any please advise? Thanks "Bofors" <bofors@xxxxxx> wrote in message news:OdKypHxaJHA.4068@xxxxxx Quote: > Ok. I will just start all over again. Copy the working copy to external > disk and try again but I don't think that's the case because I have a few > other virtual hard disk images and none of them work either. > > > Thanks > > > "Bill Grant" <not.available@xxxxxx> wrote in message > news:eIyd8$waJHA.4520@xxxxxx Quote: >> >> >> "Bofors" <bofors@xxxxxx> wrote in message >> news:ukyzZ2waJHA.5788@xxxxxx Quote: >>> I have copied my Virtual Hard disk to an extern USB drive, when i try to >>> start the OS on the Virtual disk I get the following error: >>> >>> Windows could not start because the following file is missing or >>> corrupt: >>> <Windows root>\system32\ntoskrnl.exe. >>> Please re-install a copy of the above file >>> >>> I have copied both the vhd and vmc files. I have tried all kind of >>> combinations like creatin a new vmc file, reusing the existing one but >>> nothing seems to work. One difference I am seeing between the original >>> vhd file and the copied one is the size, somehow the size of the copied >>> file is much smaller. Is it possible that the file somehow gets >>> compressed on copying? >>> >>> Any help will be greatly appreciated. >>> >> I would say that you have a corrupt .vhd file. Have you tried >> deleting it and making a fresh copy from your external drive? > |
| | Re: Copied Virtual Hard disk does not work If the USB drive formatted as FAT32 (that's usually the default on such things) and the original VHD files are over 4G? If so that's your problem, the files are getting truncated because FAT32 can't have files bigger than 4G. -- Bob Comer On Wed, 31 Dec 2008 02:04:23 -0600, "Bofors" <bofors@xxxxxx> wrote: Quote: > >Copied the vhd file to external drive and still the same problem. When I try >to run the VPC with vhd on the external drive I get the following error: > >Windows could not start becasue the following file is missing or corrupt: >\Windows\System32\config\system > >You can attempt to repair this file by starting Windows setup using the >original Setup CD-ROM >...... > >If I copy this vhd file to my main hard drive I get the other mentioned in >the original post. > >Host OS is Windows XP, guest OS is Windows Server 2003 and I am running >Virtual PC 2007. > >This problem is driving me nuts. Any please advise? > >Thanks > > >"Bofors" <bofors@xxxxxx> wrote in message >news:OdKypHxaJHA.4068@xxxxxx Quote: >> Ok. I will just start all over again. Copy the working copy to external >> disk and try again but I don't think that's the case because I have a few >> other virtual hard disk images and none of them work either. >> >> >> Thanks >> >> >> "Bill Grant" <not.available@xxxxxx> wrote in message >> news:eIyd8$waJHA.4520@xxxxxx Quote: >>> >>> >>> "Bofors" <bofors@xxxxxx> wrote in message >>> news:ukyzZ2waJHA.5788@xxxxxx >>>> I have copied my Virtual Hard disk to an extern USB drive, when i try to >>>> start the OS on the Virtual disk I get the following error: >>>> >>>> Windows could not start because the following file is missing or >>>> corrupt: >>>> <Windows root>\system32\ntoskrnl.exe. >>>> Please re-install a copy of the above file >>>> >>>> I have copied both the vhd and vmc files. I have tried all kind of >>>> combinations like creatin a new vmc file, reusing the existing one but >>>> nothing seems to work. One difference I am seeing between the original >>>> vhd file and the copied one is the size, somehow the size of the copied >>>> file is much smaller. Is it possible that the file somehow gets >>>> compressed on copying? >>>> >>>> Any help will be greatly appreciated. >>>> >>> >>> I would say that you have a corrupt .vhd file. Have you tried >>> deleting it and making a fresh copy from your external drive? >> |
| | #6 (permalink) |
| | Re: Copied Virtual Hard disk does not work "Robert Comer" <bobcomer-removeme-@xxxxxx> wrote in message news:rqpml4dmji80lc0jmdtdhrjk5f0ju7hriq@xxxxxx Quote: > If the USB drive formatted as FAT32 (that's usually the default on > such things) and the original VHD files are over 4GB? If so that's > your problem, the files are getting truncated because FAT32 can't have > files bigger than 4GB. will break it into 4GB sections as required. But do you know of any utility which will take an *existing* VHD which was created on an NTFS partition and split into 4GB sections so that it can be later copied onto a FAT32 partition...? -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #7 (permalink) |
| | Re: Copied Virtual Hard disk does not work >As I understand it, if a VHD is *first created* on a FAT32 partition, VPC Quote: >will break it into 4GB sections as required. Quote: >But do you know of any utility which will take an *existing* VHD which was >created on an NTFS partition and split into 4GB sections so that it can be >later copied onto a FAT32 partition...? FAT32 partition, make a new VM(generic, no OS needed), attach the old VHD and the new one as the second disk, boot VM using Acronis Disk Director CD image, copy partition from the old to the new. However, these days I just format the USB drive as NTFS even if it is a bit slower over USB... (I also turn on compression at the same time) -- Bob Comer On Wed, 31 Dec 2008 13:52:10 -0000, "Mark Rae [MVP]" <mark@xxxxxx> wrote: Quote: >"Robert Comer" <bobcomer-removeme-@xxxxxx> wrote in message >news:rqpml4dmji80lc0jmdtdhrjk5f0ju7hriq@xxxxxx > Quote: >> If the USB drive formatted as FAT32 (that's usually the default on >> such things) and the original VHD files are over 4GB? If so that's >> your problem, the files are getting truncated because FAT32 can't have >> files bigger than 4GB. >As I understand it, if a VHD is *first created* on a FAT32 partition, VPC >will break it into 4GB sections as required. > >But do you know of any utility which will take an *existing* VHD which was >created on an NTFS partition and split into 4GB sections so that it can be >later copied onto a FAT32 partition...? |
| | #8 (permalink) |
| | Re: Copied Virtual Hard disk does not work "Robert Comer" <bobcomer-removeme-@xxxxxx> wrote in message news:btvml4t3o7mm866mjc1od1m8bl22ueg8o1@xxxxxx Quote: Quote: >> But do you know of any utility which will take an *existing* VHD which >> was >> created on an NTFS partition and split into 4GB sections so that it can >> be >> later copied onto a FAT32 partition...? > No, I don't, but I've done that very thing by making a new VHD on a > FAT32 partition, make a new VM(generic, no OS needed), attach the old > VHD and the new one as the second disk, boot VM using Acronis Disk > Director CD image, copy partition from the old to the new. which don't support NTFS, as they have their own (UDF) format which means that Windows sees them as CDs... Quote: > However, these days I just format the USB drive as NTFS even if it is > a bit slower over USB... (I also turn on compression at the same time) compressed volumes, or is it just a question of saving space on the host's HD...? -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #9 (permalink) |
| | Re: Copied Virtual Hard disk does not work >Interesting... Do you find that VHDs perform as well (or even better) on Quote: >compressed volumes, or is it just a question of saving space on the host's >HD...? space saving is the only reason I do it. (And VHD's usually compress pretty well) I've never had good luck running VM's off of a USB drive no matter how it's formatted, eventually it gets corrupted. So I only use USB as near line storage for this very reason. I think there's a lot of bad USB controllers out there and I happen to always get one of the bad ones. -- Bob Comer On Wed, 31 Dec 2008 14:39:02 -0000, "Mark Rae [MVP]" <mark@xxxxxx> wrote: Quote: >"Robert Comer" <bobcomer-removeme-@xxxxxx> wrote in message >news:btvml4t3o7mm866mjc1od1m8bl22ueg8o1@xxxxxx > Quote: Quote: >>> But do you know of any utility which will take an *existing* VHD which >>> was >>> created on an NTFS partition and split into 4GB sections so that it can >>> be >>> later copied onto a FAT32 partition...? >> No, I don't, but I've done that very thing by making a new VHD on a >> FAT32 partition, make a new VM(generic, no OS needed), attach the old >> VHD and the new one as the second disk, boot VM using Acronis Disk >> Director CD image, copy partition from the old to the new. >Yes, that's what I do too, where possible... I have several Iomega REV disks >which don't support NTFS, as they have their own (UDF) format which means >that Windows sees them as CDs... > Quote: >> However, these days I just format the USB drive as NTFS even if it is >> a bit slower over USB... (I also turn on compression at the same time) >Interesting... Do you find that VHDs perform as well (or even better) on >compressed volumes, or is it just a question of saving space on the host's >HD...? |
| | #10 (permalink) |
| | Re: Copied Virtual Hard disk does not work In message <eJNAIW1aJHA.4480@xxxxxx> "Mark Rae [MVP]" <mark@xxxxxx> was claimed to have wrote: Quote: >Interesting... Do you find that VHDs perform as well (or even better) on >compressed volumes, or is it just a question of saving space on the host's >HD...? noticeably higher, but write speeds were just bad -- NTFS compression was great if you're using undo disks though. |
| Extract Information from Virtual Hard Disk | Virtual PC | |||
| Add virtual hard disk?? | Virtual Server | |||
| open virtual hard disk | Virtual PC | |||
| MS Virtual PC 2007 - virtual hard disk | Vista installation & setup | |||
