Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - RE: Mouse pointer of Virtual PC 2007 did not work with WindowXP Pro SP
Old 01-08-2009   #1 (permalink)
john
Quote:
> I tried to install Vista on VPC on my WindowXP Pro but the mouse pointer
> did not work. I just download Virtual PC 2007 from Microsoft Website on
> Mar-16-2007. Which version do I need to download in order to try VPC2007?
> Regards,
> John Dang
I am having the same mouse behavior problem when I am doing a remote desktop control on another virtual PC. I tried resolutions, it still doesnt fix the problem. Does anybody know the resolution for this?
Hope to hear from someone out there. thanks
Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com
Old 01-08-2009   #2 (permalink)
Steve Jain [MVP]
Re: Mouse pointer of Virtual PC 2007 did not work with WindowXP Pro SP
On Fri, 09 Jan 2009 04:03:54 GMT, "john"<jheng@xxxxxx>
>> Regards,
>> John Dang
Have you installed the VM Additions? You need those for the pointer
to work correctly with Remote Desktop.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
Mouse does not work on Microsoft Word 2007 Vista hardware & devices
net card not work virtual pc 2007 Virtual PC
Re: Virtual PC 2007 Mouse pointer disappears from input fields in guest OS Virtual PC
RE: Mouse pointer of Virtual PC 2007 did not work with WindowXP Pro SP Virtual PC
Mouse DPI and pointer speed at the Mouse Properties. Vista General
