Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Re: Why dowsn't VPC recognize wireless adapter
Old 01-10-2009   #1 (permalink)
Freek Versteijn
It would be great if I could test wireless networking within the VPC though..
But I understand the why and the concept of hardware encapsulation.
"Steve Jain" wrote:
Quote:
> On Mon, 7 Aug 2006 13:47:01 -0700, KCav
> <KCav@xxxxxx> wrote:
Quote:
> >I am unable to get VPC, Build 2600.xpsp_sp2_rtm.040803-2158; Service Pack 2
> >to communicate with wireless router. The Host uses Intel Pro/Wireless 2915ABG
> >adapter; connected to 2Wire701HG gateway; Windows reports excellent
> >connection speed 54mps. Mean while on VPC Windows does not recognize a
> >wireless connection even though I just set one up. Please advise how to get
> >VPC to recognize the wireless card and its configuration.
> A VM will never see a wireless card. VPC emulates a specific set of
> hardware, a wireless card is not one of them. The host's physical
> hardware is irrelevant when it comes to what a VM will see. A VM will
> always see the same emulated hardware, in the case of a NIC, it's the
> Intel 21140. The rest of the emulated hardware is listed in the VPC
> Help.
> If you mean that VPC does not list the wireless card in the network
> settings, make sure you've got the most recent driver from Intel and
> that the VMNS driver is installed under the NIC in the host's network
> properties.
> Cheers,
> Steve Jain, Virtual Machine MVP
> http://vpc.essjae.com/
> I do not work for Microsoft.
Old 01-10-2009   #2 (permalink)
Bob Campbell
"Freek Versteijn" <FreekVersteijn@xxxxxx> wrote in
message news:7583D691-7F04-431D-B12D-E952DCF7C6A8@xxxxxx
> though..
I thought that VPC would use whatever NIC you have, wireless or wired. In
the settings, tell it to use the wireless card. It will still show in the
VM as the same old wired card, however.
Old 01-12-2009   #3 (permalink)
Freek Versteijn
Hi Bob
That is correct, but it is exposed by the host as a generic ethernet
card/interface. So the VM can not see that there is a wireless network card
installed.
> > though..
Vista won't recognize Verizon wireless card Drivers
help with network (usb wireless adapter or wireless router) Network & Sharing
Vista Supported Wireless USB Adapter / Wireless PCI Card Vista General
Vista wont recognize my wireless network Vista networking & sharing
Vista doesn't recognize wireless firewall... Vista General
