Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Home Premium 64-bit "not supported."
Old 01-11-2009   #1 (permalink)
cking123
Whenever I try to install Microsoft Virtual PC 2007 SP1, I get a pop-up
message after clicking 'next' the first time. It states, "You are not running
on a supported operating system. Please see Microsoft Virtual PC help for the
list of supported host operating systems."
Then it continues like it's going to install only to see "The wizard was
interrupted before Microsoft Virtual PC 2007 SP1 could be completely
installed.
"Your system has not been modified. To install this program at a later time,
please run the installation again."
Should this be happening? If not how do I get around it.
Old 01-11-2009   #2 (permalink)
Mark Rae [MVP]
Re: Home Premium 64-bit "not supported."
"cking123" <cking123@xxxxxx> wrote in message
news:7AA3DF35-D774-4CEF-A5DA-667D5026E1C4@xxxxxx
> running
> the
Yes, that's correct. Neither the Home Basic edition nor the Home Premium
edition of Vista is officially supported as a host for VPC 2007. However, it
will work fine.
> installed.
> time,
Are you running XFire?
Mark Rae
ASP.NET MVP
http://www.markrae.net
Solved Fix for "Deleted Items not showing in Recycle Bin with Vista Home Premium X64" General Discussion
"No such interface supported" when connecting Reliability andPerformance Monitor to remote Vista Home Premium machine Vista performance & maintenance
Can Vista Home Premium capture "still shots" from a family video C Vista music pictures video
upgrading from "Vista Home Premium" to "Vista Business" or "Vista Ultimate" Vista account administration
Have Vista Home Premium - is "Business" or "Ultimate" better? Vista General
