Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Problems installing MS Virtual PC 2007
Old 01-11-2009   #1 (permalink)
Romboud
I've got a question regarding installing MS Virtual PC 2007.
I'm trying to install this software on a Vista Ultimate 64-bit machine.
While it's installing my internet connection disconnects and it seems that
the installation hangs (the progress bar of the installation is full, but he
doesn't continue)
Have any of you have ideas to solve this problem?
Old 01-12-2009   #2 (permalink)
Robert Riebisch
Re: Problems installing MS Virtual PC 2007
Romboud wrote:
What "security" software, e.g., anti-virus or personal firewall, are you
running?
Robert Riebisch
Bitte NUR in der Newsgroup antworten!
Please reply to the Newsgroup ONLY!
Old 01-20-2009   #3 (permalink)
Pete
RE: Problems installing MS Virtual PC 2007
Quote:
> Hi,
> doesn't continue)
Virtual PC 2007 only supports 32-bit guest operating systems. If you want to try the 64-bit edition in a virtualized environment I suggest to use Hyper-V.
http://www.microsoft.com/servers/hyp...r/default.mspx
Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com
Old 01-20-2009   #4 (permalink)
Grand_Poobah
There are two versions of VPC2007 - a 32-bit and a 64-bit. Make sure
you are using the 64-bit version for installation on a Vista 64-bit host.
GP
Quote:
Quote:
>> Hi,
>> doesn't continue)
Old 01-21-2009   #5 (permalink)
Mark Rae [MVP]
"Grand_Poobah" <whatever@xxxxxx> wrote in message
news:%23SD1GW2eJHA.1252@xxxxxx
>>> that
>>> but he doesn't continue)
>> Hyper-V.
Not quite... Both are 32-bit - one has a different virtualisation driver
designed to be installed on 64-bit systems, but it's still a 32-bit app:
http://vpc.visualwin.com/ngfaq.aspx#18
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 01-21-2009   #6 (permalink)
Grand_Poobah
>>>> seems that
>>>> full, but he doesn't continue)
>>> to use Hyper-V.
true, but to avoid confusion I try to think of them as two separate
downloads - even MS thinks so and identifies them as such. It even
provides two different links.
GP
Old 01-21-2009   #7 (permalink)
Mark Rae [MVP]
news:udVyMr8eJHA.3392@xxxxxx
> I try to think of them as two separate downloads
So do I - because they are...
Quote:
> even MS thinks so and identifies them as such. It even provides two
> different links.
No choice, since they're two different installs, one for use on a 32-bit OS
and the other for use on a 64-bit host...
Mark Rae
ASP.NET MVP
Old 01-21-2009   #8 (permalink)
Grand_Poobah
>>> driver designed to be installed on 64-bit systems, but it's still a
>>> 32-bit app:
>> different links.
> OS and the other for use on a 64-bit host...
Is there a point? Or do you just like to argue a lot
GP
Old 01-21-2009   #9 (permalink)
asdfg
>>>> 32-bit app:
>>> different links.
>> 32-bit OS and the other for use on a 64-bit host...
> GP
he's an ass that likes to argue
Old 01-21-2009   #10 (permalink)
Grand_Poobah
>>>>> 32-bit app:
>>>> different links.
>> GP
Absolutely NOT. Mark gives some very good advice. He and I knew what I
meant but we both tend to be pedantic.
GP
Installing Virtual PC 2007 SP1 on Windows 7 (64 bit) fails... Virtual PC
Installing Windows XP on Virtual PC 2007 Virtual PC
Installing Ubuntu under MS Virtual PC 2007 Software
Installing XP into Vista Ultimate with Virtual PC 2007 Vista General
Installing Vista Ultimate in Virtual PC 2007 and EULA? Vista installation & setup
