Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - RE: Mouse pointer of Virtual PC 2007 did not work with WindowXP Pro SP
Old 01-15-2009   #1 (permalink)
Zvi
Quote:
> I tried to install Vista on VPC on my WindowXP Pro but the mouse pointer
> did not work. I just download Virtual PC 2007 from Microsoft Website on
> Mar-16-2007. Which version do I need to download in order to try VPC2007?
> Regards,
> John Dang
Installing VM Additions really solves this problem - now I can work correctly on Vista installed inside VirtualPC, when working remotely on host machine.
But - it works very-very slow ...
Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com
Mouse does not work on Microsoft Word 2007 Vista hardware & devices
net card not work virtual pc 2007 Virtual PC
Re: Virtual PC 2007 Mouse pointer disappears from input fields in guest OS Virtual PC
RE: Mouse pointer of Virtual PC 2007 did not work with WindowXP Pro SP Virtual PC
Mouse DPI and pointer speed at the Mouse Properties. Vista General
