| | One way network connection problems I'm running MS Virtual PC 2007 on my Vista SP1 system. I'm using the Virtual Image of Visual Studio 2010 CTP (Windows Server 2008 Standard). I want to connect to SQL Server 2008 installed on the image but can't get any connection. Vista and virtual machine are in the same IP network. Inside the virtual machine I can access my Vista PC without any problems (ping, shares etc.) through my network. My problem is, I can't get any access from my Vista PC to the virutal machine through my network. The first adapter in the virtual machine settings is set to my Vista PCs network card driver. Can anyone help me to get access from my Vista PC to the virtual machine ? |
| | Re: One way network connection problems On Sat, 17 Jan 2009 01:50:01 -0800, Jens Friedrich <JensFriedrich@xxxxxx> wrote: Quote: >I'm running MS Virtual PC 2007 on my Vista SP1 system. > >I'm using the Virtual Image of Visual Studio 2010 CTP (Windows Server 2008 >Standard). I want to connect to SQL Server 2008 installed on the image but >can't get any connection. Vista and virtual machine are in the same IP >network. > >Inside the virtual machine I can access my Vista PC without any problems >(ping, shares etc.) through my network. > >My problem is, I can't get any access from my Vista PC to the virutal >machine through my network. The first adapter in the virtual machine settings >is set to my Vista PCs network card driver. > >Can anyone help me to get access from my Vista PC to the virtual machine ? access. Check that the Windows Firewall is set up correctly. -- Bo Berglund (Sweden) |
| | Re: One way network connection problems "Bo Berglund" wrote: Quote: > Firewall settings on the virtual machine are most likely stopping the > access. Check that the Windows Firewall is set up correctly. the Windows Firewall and ping and access worked. The only thing I had to add was the SQL Server Port to get also access outside the virtual machine. Thanx a lot. |
| Network connection problems with vista 64 bit | Network & Sharing | |||
| Multiple network connection problems | Network & Sharing | |||
| Vista Intermittent Network Connection Problems | Vista General | |||
| Wireless Network Connection Problems | Vista networking & sharing | |||
| RC2 network connection problems to Internet | Vista General | |||
