| | Virtual Machine Additions doesn't work with win 7 7000 i tried to install windowa 7 build 7000 on virtual pc 2007 and everthing works fine a bit slow because i can't use more then 700MB on my old computer but fine but if i try to install Virtual Machine Additions after restart i get BSOD does any one eles tried to do the same as well and it worked well for him? 10x in advance. ![]() |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 "aviramof" <aviramof@xxxxxx> wrote in message news:B683C797-8BD0-429D-83D8-A52C2311DF1C@xxxxxx Quote: >i tried to install windowa 7 build 7000 on virtual pc 2007 and everthing > works fine a bit slow because i can't use more then 700MB on my old > computer > but fine but if i try to install Virtual Machine Additions after restart i > get BSOD does any one eles tried to do the same as well and it worked well > for him? problems yours is slow because you don't have the additions installed your 700 meg is plenty for running 7 in a vm i have have 7 in a vm with just 512 megs and it ran fine periods are your friend! |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 i have managed to install it but when i try to copy files a directory with this name {3B7A0090-5AB6-4838-B146-968EBE8F54D1} or something similier is created and i get an error messege and the file is not copied. |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 "aviramof" <aviramof@xxxxxx> wrote in message news:6AA5CC08-41B4-419F-91EA-48DA62853004@xxxxxx Quote: > I get an error message -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 I get the same thing, when asking on the tehnet forums seems others having the same problems. Dragging and dropping or copying and pasting in and out of the guest seems to create that folder with nothing inside it. Most have said to network the host and guest and do it that way. I did and found that to work better. robin "aviramof" <aviramof@xxxxxx> wrote in message news:6AA5CC08-41B4-419F-91EA-48DA62853004@xxxxxx Quote: > i have managed to install it but when i try to copy files a directory with > this name > {3B7A0090-5AB6-4838-B146-968EBE8F54D1} or something similier is created > and > i get an error messege and the file is not copied. |
| | #6 (permalink) |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 Virtual PC encountered an error on the host while copying files. An error in virtual PC has occurred (d6). that is the problme and beside that windows 7 runs very slowly in virtual pc 2007 sp1 now i know i have an old computer but this is quite ridicilus how slow it is so perhaps it's time for virtual PC 2009 or at least SP2 ![]() 10x in advance for all your help. ![]() |
| | #7 (permalink) |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 "aviramof" <aviramof@xxxxxx> wrote in message news:FC9CF8D8-ADA7-4D09-B006-5A953D38C523@xxxxxx Quote: > Virtual PC encountered an error on the host while copying files. > > An error in virtual PC has occurred (d6). > > that is the problme and beside that windows 7 runs very slowly in virtual > pc > 2007 sp1 now i know i have an old computer but this is quite ridicilus how > slow it is so perhaps it's time for virtual PC 2009 or at least SP2 ![]() > > 10x in advance for all your help. ![]() runs at almost 100%cpu. I am wondering when I add memory if this will change but the host is running around 45% cpu running vista now. On the desktop- Windows 7 as the guest runs about 50% cpu and the laptop should do better since it is a duel core 2 processor when the desktop is an amd dual processor. I do not understand why |
| | #8 (permalink) |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 On Sun, 18 Jan 2009 18:58:33 -0500, "robinb" <robinbk9@xxxxxx> wrote: Quote: > > > >"aviramof" <aviramof@xxxxxx> wrote in message >news:FC9CF8D8-ADA7-4D09-B006-5A953D38C523@xxxxxx Quote: >> Virtual PC encountered an error on the host while copying files. >> >> An error in virtual PC has occurred (d6). >> >> that is the problme and beside that windows 7 runs very slowly in virtual >> pc >> 2007 sp1 now i know i have an old computer but this is quite ridicilus how >> slow it is so perhaps it's time for virtual PC 2009 or at least SP2 ![]() >> >> 10x in advance for all your help. ![]() >I am noticing more on my laptop that windows 7 is running much slower and >runs at almost 100%cpu. I am wondering when I add memory if this will >change but the host is running around 45% cpu running vista now. >On the desktop- Windows 7 as the guest runs about 50% cpu and the laptop >should do better since it is a duel core 2 processor when the desktop is an >amd dual processor. I do not understand why > instead of 7200rpm. Also, CPU power savings will drastically lower a VM's performance. When the CPU is throttled back everything in a VM is affected. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | #9 (permalink) |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 so is there any news about new vmaditions or new VM version and etc? 10x in advance. |
| | #10 (permalink) |
| | Re: Virtual Machine Additions doesn't work with win 7 7000 "aviramof" <aviramof@xxxxxx> wrote in message news:0DF5CA4D-BFDE-4031-832F-7C713799B2A3@xxxxxx Quote: > so is there any news about new vmaditions or new VM version and etc? > > 10x in advance. Longer answer. 1. Nothing has been announced about a new version of VPC, although the product group insist it is not dead and something is being developed. 2. I would not expect to see VMAdditions which support for Win 7 until after RTM of Win 7. |
| Virtual PC 2007 - Install Virtual Machine Additions | Tutorials | |||
| VPC 2007 SP1 - Virtual Machine Additions crashes | Virtual PC | |||
| Install Virtual Machine Additions | Virtual PC | |||
| Vista and Virtual Machine Additions | Virtual PC | |||
| Uninstalling Virtual Machine Additions | Vista General | |||
