Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - RE: Running OS X on Virtual PC
Old 01-20-2009   #1 (permalink)
3232design
Quote:
> Hi,
> Is it possible to install OS X (or any other version of MAC) on a Virtual PC
> (on a PC)?
I use an application called 'Synergy' which allows me to use the same mouse and keyboard I use for my Mac to control my PC. If you already have a monitor and they can see each other over a TCP/IP network, Synergy should work. You can even copy and paste text between computers. Just roll your mouse off one screen and it appears on the other computer's screen. The only problem is remembering that you have to use the ctrl key instead of the apple key for shortcuts, but otherwise it's pretty flawless.
Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com
I want to setup 2 DCs running on Virtual PC Virtual PC
Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 Virtual Server
running Dos 6.2 inside Virtual PC Virtual PC
Is running Virtual PC difficult? Vista General
Virtual PC running XP is too slow Vista General
