| Vista Ultimate 32bit | Problem running Complete Vista backup in VPC I read somewhere on the web that the Vista Complete Backup could be run with VPC 2007. But I can not get it to work. I installed VPC 2007 and created a quest. I changed the vhd to point to the one created by Vista Complete Backup. When I try to start the guest it tries to do DHCP and that is it. It acts like it did not use the vhd I specified. My PC is running Vista Ultimate 32. Thanks: Jack Allen |
| | Re: Problem running Complete Vista backup in VPC On Fri, 23 Jan 2009 09:43:05 -0600, jca001 <guest@xxxxxx-email.com> wrote: Quote: > >I read somewhere on the web that the Vista Complete Backup could be run >with VPC 2007. But I can not get it to work. > >I installed VPC 2007 and created a quest. >I changed the vhd to point to the one created by Vista Complete Backup. > >When I try to start the guest it tries to do DHCP and that is it. It >acts like it did not use the vhd I specified. > >My PC is running Vista Ultimate 32. won't be usable in a VPC guest until it is made bootable. -- Bo Berglund (Sweden) |
| Vista Ultimate 32bit | Re: Problem running Complete Vista backup in VPC When you say make it bootable, do you mean the guest, by loading an OS? Then how do you access the vhd file? Or do you mean do something to the vhd file? Thanks: Jack Allen |
| | Re: Problem running Complete Vista backup in VPC "jca001" <guest@xxxxxx-email.com> wrote in message news:a847b95a8384356c8d8d2619509bc50d@xxxxxx-gateway.com... Quote: > > When you say make it bootable, do you mean the guest, by loading an OS? > > Then how do you access the vhd file? > > Or do you mean do something to the vhd file? > > Thanks: > Jack Allen > > > -- > jca001 backup uses the .vhd format to create a backup. It is just that - a backup file. It is not a bootable system image. It will not boot up in VPC. It is possible to make a bootable image of a running system, but Vista Backup is not it. |
| | Re: Problem running Complete Vista backup in VPC "Bill Grant" <not.available@xxxxxx> wrote in message news:OH1ePRefJHA.5572@xxxxxx Quote: > What Bo really means is that the info you read is not correct. Vista > backup uses the .vhd format to create a backup. It is just that - a backup > file. It is not a bootable system image. It will not boot up in VPC. That's right. And in addition, even if it were possible to boot the backup vhd in VPC, you'd have to go through the whole process of applying all of the different hardware drivers since the vhd will be expecting to find the emulated hardware of a virtual machine, and won't know anything about the host's physical hardware... -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #6 (permalink) |
| Vista Ultimate 32bit | Re: Problem running Complete Vista backup in VPC Thanks for clarification. I guess I just misread the post else where. It would have been nice to be able to use it to get one or two files if needed. Do you think a complete backup to dvds could be used and restore to a guest? Thanks: Jack Allen |
| | #7 (permalink) |
| | Re: Problem running Complete Vista backup in VPC "jca001" <guest@xxxxxx-email.com> wrote in message news:b20ce5cf6c8a265da2b84651d63da235@xxxxxx-gateway.com... Quote: > Thanks for clarification. > > I guess I just misread the post else where. It would have been nice to > be able to use it to get one or two files if needed. 2) Select (BUT DON'T START!) an existing virtual machine, preferably with Vista installed on it 3) Click the Settings button 4) In the left pane, click Hard Disk 2 5) In the right pane, select the backup vhd 6) Start the virtual machine I should point out that I haven't actually tried this but, so long as the backup vhd isn't compressed / encrypted in a specific way, it should now appear as the virtual machine's D: drive... Quote: > Do you think a complete backup to dvds could be used and restore to a > guest? resulting vhd is split over more than one disk if it's too large to fit on the first one... If you want to back up a physical machine and restore it onto a virtual machine, I would suggest using Acronis Universal Restore: http://www.acronis.com/enterprise/pr...l-restore.html It's not free, but it's pretty much guaranteed to work... -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #8 (permalink) |
| | Re: Problem running Complete Vista backup in VPC If you need to access to your vista backup (vhd file) just install Virtual Server 2005 (free) and use vhdmount utility. With this, you can mount your vhd backup to your PC as a drive and access it as you access to a regular thumb-drive or external USB disk. Command-line to do that: vhdmount.exe /m <VHD file path> <Drive letter> "jca001" wrote: Quote: > > Thanks for clarification. > > I guess I just misread the post else where. It would have been nice to > be able to use it to get one or two files if needed. > > Do you think a complete backup to dvds could be used and restore to a > guest? > > Thanks: > Jack Allen > > > -- > jca001 > |
Vista Complete Backup problem | General Discussion | |||
| Problem with Complete PC Backup, not so complete | Vista General | |||
| Problem with Starting Vista Complete Backup | Vista General | |||
| Vista Complete Backup Problem | Vista performance & maintenance | |||
| Complete PC backup problem | Vista file management | |||
