| | Using USB device on Virtual Machine Hi peeps, I have a little problem, thats proberly easily fixed? I have VPC instal and running, with a Virtual Machine running XP on it. When I plug in my USB memory stick Vista picks it up but nothing shows up in the Virtual Machine. How can I use the device in my XP Virtual Machine? Thanks in advance for any help. Zane |
| error: Virtual PC could not open the Virtual Machine Network Servicesdriver | Virtual PC | |||
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 | Virtual Server | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
| Moving Virtual Machine from Hyper-v to Virtual Server 2005 | Virtual Server | |||
