Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Virtual PC and Home premium x64
Old 01-27-2009   #1 (permalink)
Windows 7 x64 (7229)
Sorry if this has been asked before. I want to get Windows 7 on a partition ASAP. Vista Home Premium is not on the list of supported OS. What is up with that? Does it work anyway?
Old 01-28-2009   #2 (permalink)
Mark Rae [MVP]
Re: Virtual PC and Home premium x64
"nate42nd" <guest@xxxxxx-email.com> wrote in message
news:759d44430388add2bc0636a9e9f683e3@xxxxxx-gateway.com...
> partition ASAP.
Your question is not clear...
You're posting in a Virtual PC newsgroup, but with Virtual PC, there is no
question whatsoever of partitions. It doesn't create a new partition on your
host's hard drive, or anything like that. When you say "I want to get
Windows 7 on a partition", do you mean that you want to create a new
partition for Windows 7 so that you can dual-boot...? If so, then Virtual PC
won't help you. You'll need some disk partitioning software e.g. Partition
Magic unless you are happy to trash your existing machine and rebuild it
with two partitions...
Alternatively, if you mean that you want to use Virtual PC so that you can
run Windows 7 in a virtual machine, then that's completely different, but
simple enough. Just make sure that you select Vista as the target operating
system template when you create the new virtual machine.
http://blogs.msdn.com/virtual_pc_guy...windows-7.aspx
It's not perfect yet - Windows 7 is still in early beta - but it works well
enough, though lots of people have reported various problems with sound,
most of which can be fixed:
http://www.google.co.uk/search?sourc...indows+7+sound
There are no Additions specifically for Windows 7 yet, but it seems to work
OK with the Vista Additions
The Home editions of Vista are not supported host OS for Virtual PC 2007.
However, they work perfectly well - just ignore the warning when you
install...
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 01-28-2009   #3 (permalink)
install...
That was my question, will it work even though it says it's not supported...thanks.
Old 01-28-2009   #4 (permalink)
Mark Rae [MVP]
news:da462ee9933024360739743444a16af6@xxxxxx-gateway.com...
Quote:
>> 2007.
>> install...
> supported...thanks.
So what did you mean by "I want to get Windows 7 on a partition"?
Mark Rae
ASP.NET MVP
Old 01-28-2009   #5 (permalink)
I didn't understand at the time of the post how VM worked. Now I do. I really wanted to know if I could use VM on Vista Home Premium x64. Sorry for the confusion and thanks for the help.
Old 01-28-2009   #6 (permalink)
Mark Rae [MVP]
news:886384c85ed4a0e1bf937be0fe7d9ec3@xxxxxx-gateway.com...
Understood. FYI, you can find a great deal of useful information in the VPC
Help file, and there is also a FAQ for this newsgroup:
http://vpc.visualwin.com/ngfaq.aspx
Mark Rae
ASP.NET MVP
Re: Will Virtual Server work with Vista Home Premium Virtual PC
RE: Vista Home Premium Edition - Virtual PC 2007 Virtual PC
Vista Home Premium .. Can't install Virtual Server.. so how do Iautomatically start a Virtual PC without a login? Virtual PC
No Virtual PC for Vista Home Premium Vista General
Cannot set virtual memory Vista Home Premium Vista performance & maintenance
