Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Printer problem!
Old 02-01-2009   #1 (permalink)
VPC MAN
Printer problem!
Hey :]
in my vista my printer dosent work (in hp there are no new drivers :\)
so i need to install my printer on xp (in the vpc..)
so my question is that: how do i install my printer that connected via a usb
to the xp in the vpc?!
tnx alottt!@!!@!@@! :]
Old 02-01-2009   #2 (permalink)
Robert Riebisch
Re: Printer problem!
VPC doesn't support USB. Try VMware (Player) or VirtualBox instead.
Robert Riebisch
Bitte NUR in der Newsgroup antworten!
Please reply to the Newsgroup ONLY!
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
printer problem to domain's printer Vista General
Printer problem Vista General
Add printer problem Vista print fax & scan
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
