Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Is it possible to run both VPC 2004 and VPC 2007 on the same host
Old 02-01-2009   #1 (permalink)
Don
I am currently running VPC 2007 SP1. From what I can tell, the oldest MS OS
it supports is Win98 SE, whereas VPC 2004 SP1 supports the older MS-DOS and
Windows products.
My question is whether it is possible to also install VPC 2004 on my host PC
without interfering with my VPC 2007 installation.
Don
Old 02-02-2009   #2 (permalink)
Jeff Gaines
Re: Is it possible to run both VPC 2004 and VPC 2007 on the same host
On 02/02/2009 in message
<B5B6136F-E999-4039-8E8D-A75DEF1AB089@xxxxxx> Don wrote:
>OS
>Windows products.
>PC
I am using VPC 2007 here with older OS's back to DOS 6.22 running fine. I
don't think you need to install VPC 2004.
Jeff Gaines Damerham Hampshire UK
There is absolutely no substitute for a genuine lack of preparation
Old 02-02-2009   #3 (permalink)
Dave Warren
In message <B5B6136F-E999-4039-8E8D-A75DEF1AB089@xxxxxx> Don
>Windows products.
2007 can run older OSes, it's just not considered a supported
configuration, so Microsoft won't provide assistance with this
situation.
I believe you'll also need to keep the VM Addition from the old version,
although I can't speak to that, I've got all of my Legacy OSes on VMWare
now.
Old 02-02-2009   #4 (permalink)
Don
Thank you...your information has been very useful.
Don
"Bob Campbell" wrote:
Quote:
> "Dave Warren" <dave-usenet@xxxxxx> wrote in message
> news:dgeeo4t8b2cmlu8e3ucb16f978h5bjmtkn@xxxxxx
> This is true. VPC 2007 does not have the DOS VM Additions. I use the
> additions from 2004 and run DOS 6.22 in VPC 2007 with no problems.
Old 02-02-2009   #5 (permalink)
Don
Thank you...your information has been very helpful.
Don
> >OS
> >Windows products.
> >PC
Old 02-03-2009   #6 (permalink)
Don
Where can I find a download of the VM Addition for VPC 2004? I've read that
VPC 2004 was originally distributed on a CD, and the Additions were in a
folder on that CD. It appears that MS only has a download for VPC 2004 SP1,
and not a separate one for the Additions.
Don
Old 02-03-2009   #7 (permalink)
Steve Jain [MVP]
On Mon, 2 Feb 2009 22:06:00 -0800, Don <don.wolfe@xxxxxx (donotspam)>
You can download the full VPC app and extract, or get the additions
from my website.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
Old 02-03-2009   #8 (permalink)
Don
Excellant! Thank you!
Don
> from my website.
> Cheers,
Old 02-04-2009   #9 (permalink)
Bo Berglund
On Sun, 1 Feb 2009 19:00:01 -0800, Don <don.wolfe@xxxxxx (donotspam)>
>Windows products.
Yes you can. I do it all the time.
You have to install VPC2004 *after* VPC2007 though, because the
VPC2007 installer detects the VPC2004 being present and requires it to
be unbinstalled first.
When you install VPC2004 make sure to select the Custom install so you
can change the install directory! You *must* use a different install
dir otherwise you will trash it.
Then you also have to manually create a shortcutr to VPC2004 because
the existing one will start VPC2007.
Finally, you cannot run both at the same time...
Bo Berglund (Sweden)
Virtual PC 2004 upgrade to 2007 Add an existing virtual machine Virtual PC
installing Virtual PC 2004 or 2007 eliminiating internet connectio PowerShell
Virtual PC 2004 vs 2007 Vista General
Re: Virtual PC 2004 vs 2007 Vista General
Will Vista run Virtual PC 2004? 2007 Beta? Vista General
