Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Switch between two virtual PCs
Old 02-02-2009   #1 (permalink)
Lingzhen Zhao
I installed Microsoft Virtual PC 2007. How can I switch between the two
virtual PCs by using a hotkey?
Thank you!
Old 02-02-2009   #2 (permalink)
Mark Rae [MVP]
Re: Switch between two virtual PCs
"Lingzhen Zhao" <Lingzhen Zhao@xxxxxx> wrote in message
news:C5223DD7-926A-4E6B-B697-E2967E537379@xxxxxx
Same way as you would switch between any two applications running in
Windows - Alt-Tab
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 02-02-2009   #3 (permalink)
Lingzhen Zhao
Mark,
Thank you for your reply! I found it works only the right Alt and Tab, not
the left Alt.
Does any one know how to make a customized hotkey, such as an F key? I am
going to use it as public computer and switch between two programs, both of
the programs have full screen covered and unable to use mouse click.
Thank you!
Lingzhen
> Windows - Alt-Tab
> Mark Rae
> ASP.NET MVP
Old 02-02-2009   #4 (permalink)
Lingzhen Zhao
I find Right Alt -Tab does not work at Full Screen mode. Is it possible to
make the hotkey works in Full Screen?
Thanks,
Lingzhen
> Windows - Alt-Tab
> Mark Rae
> ASP.NET MVP
Old 02-04-2009   #5 (permalink)
Big Dany
You may try Left Alt key instead. This occurs because the Right Alt is the
host key.
"Lingzhen Zhao" <LingzhenZhao@xxxxxx> wrote in message
news:8AEEB84A-5EEE-411F-8262-3B9C85B51D79@xxxxxx
> to
> Thanks,
> Lingzhen
>> message
>> > two
>> Windows - Alt-Tab
>> Mark Rae
>> ASP.NET MVP
Old 03-09-2009   #6 (permalink)
pottomcarool
RE: Switch between two virtual PCs
hey guys,
i have the same problem, and i should know as soon as possible that how to
switch with hotkeys between 2 Virtual PC... or how to set these hotkeys. i'm
actually not using the VPCs in FullScreen mode... but i've tried that
too...and none of the Alt keys worked (left or right with tab button)
anyways....
thank you for help...
RE: Virtual Server could not open its emulated Ethernet switch driver Virtual Server
Virtual PC causes KVM to switch Virtual PC
Vista Home Premium .. Can't install Virtual Server.. so how do Iautomatically start a Virtual PC without a login? Virtual PC
Moving Virtual Machine from Hyper-v to Virtual Server 2005 Virtual Server
How To: Windows Performance Monitor Virtual Switch Port instance IDto Virtual NIC or VM Virtual Server
