unable to connect my virtual Machine through Remote Desktop Connec
  1. #1
    Ansar Guest
    I have a WinXP SP2 machine with virtual PC installed. I have
    installed windows server 2003 as a virtual machine.
    I want to use the virtual win2k3 server as a test database server and would
    like to connect directly to it with remote desktop on my Desktop. I cannot
    make this work.
    My network is a simple 192.168.10.20 - 192.168.10.50 range assigned through
    DHCP. I can connect to all,my other PC's fine. So the network is OK. But the
    virtual machine has getting
    192.168.131.66 as IP-address through DHCP Server. But this Ip address is not
    in my network, which is in another range.
    I cannot connect to the virtual machine with remote desktop but i can ping
    to virtual machine. I tried to disable the firewall on the virtual machine,
    but still no go.
    I need to get access my Virtual machine through remote desktop connection.
    Does anyone know how to solve this?
  2. #2
    Steve Jain [MVP] Guest
    Re: unable to connect my virtual Machine through Remote Desktop Connec
    On Mon, 2 Feb 2009 22:00:01 -0800, Ansar
    <Ansar@xxxxxx> wrote:
    >Hi,
    >make this work.
    >but still no go.
    If you're getting a 131 range IP, then you're using Shared Networking.
    You won't get host-guest communication using it. Under the Network
    settings change from Shared Networking to your NIC listed there.
    This will get your guest an IP in the correct range .10.x and should
    also allow RDP. After you make the switch reboot the guest OS for the
    easiest config.
    Cheers,
    Steve Jain, Virtual Machine MVP
    http://vpc.essjae.com/
  3. #3
    Ansar Guest
    Hello Steve,
    Thank you for your reply!!
    I am not get the point that you have mentioned "Under the Network
    settings change from Shared Networking to your NIC listed there" .
    Please tell me the configuration once again... it could be very helpful for
    me..
    I have configured the IP address manually range of 192.168.10.XX. but still
    the problem exists...
    Once again thanks ...
    Regards
    Ansar
    > >Hi,
    > >make this work.
    > >but still no go.
    > easiest config.
    > Cheers,
  4. #4
    On Tue, 3 Feb 2009 22:34:00 -0800, Ansar
    >Hello Steve,
    >me..
    Go to the Settings of the VM
    Under the Networking section, where adapter 1 is specified, click the
    selection menu.
    Change from Shared Networking to your NIC listed there, what is
    actually listed depends on the NIC installed. On mine it says "Intel
    82567LM Gigabit Network"
    Once this is selected your VM will be connected directly to your
    host's network instead of via NAT in Shared Networking.
    After this reboot, the VM so the correct IP can be gotten from your
    DHCP.
    Cheers,
  5. #5
    Ansar Guest
    Hello Steve,
    Thanks for your valuable reply!!
    I have tried to change the settings of VM from shared networking to NIC
    card. But my local system NIC adpater is not showing there...it only shows
    local only, Not connected, shared networking (NAT).
    I have changed the shared networking to local only and restarted the server.
    But still Virtual Machine is not getting Ip address from DHCP Server.
    Please reply..
    Regards
    Ansar
    > >Hello Steve,
    > >me..
    > selection menu.
    > DHCP.
    > Cheers,
  6. #6
    Bo Berglund Guest
    On Thu, 5 Feb 2009 20:01:01 -0800, Ansar
    >> >Hello Steve,
    >> >me..
    >> selection menu.
    >> DHCP.
    If your physical NIC does not show up in the list then you have a
    problem with the NIC driver or you are using a wireless NIC on your
    host.
    First attempt at solving this:
    - Open the properties of your NIC (on the host)
    - Make sure that the "Virtual Machine Network Services" item is
    checked in the list. If it is not then:
    - Check it and OK out.
    - Now stop and start VPC2007
    - Go to the guest properties again and see if the NIC has appeared
    in the list. If so select it and start the guest.
    - Chances are that the networking will now begin to work as you
    want.
    Second attempt:
    - If the above does not work then you need to locate a newer driver
    for your network card on the host. Your NIC driver probably does not
    cooperate with the VMNS services in the present version....
    Finally:
    Local only will not give you any connectivity at all! It is meant to
    be used for *isolated* guest networks where the intention is that the
    guests will *not* be visible to any other computers than the virtual
    ones, including being invisible from the host.
    Bo Berglund (Sweden)
unable to connect my virtual Machine through Remote Desktop Connec problems?
Unable to connect to internet from virtual machine on virtual serv Rob Virtual Server 0 06 Feb 2010
How to connect my virtual Machine from my desktop ansur Virtual PC 9 19 Jan 2010
From Virtual Server, Unable to connect to Remote SQL Server 2008 D VR Virtual Server 0 22 Dec 2008
Unable to install Virtual Guest Services on virtual machine Marc Medina Virtual Server 6 08 Dec 2008
Remote Desktop 6.0 - Unable to connect Fabricel Vista General 31 09 Mar 2007
