| Vista Home Premium 32bit | How to connect my virtual Machine from my desktop Hi I am using vista home premium stand alone notebook. I had created windows 2003 Virtual machine with SQL 2005 running in it. I need to connect SQL 2005 from my desk top which was sql client installed in it. can any opn pls help me to set the ip / dns settings in vista and VPC. Thanks a ton in advance. Regards Anbu |
| | Re: How to connect my virtual Machine from my desktop "ansur" <guest@xxxxxx-email.com> wrote in message news:4c062945013f05296b88f36a176e94ab@xxxxxx-gateway.com... Quote: > > Hi > > I am using vista home premium stand alone notebook. I had created > windows 2003 Virtual machine with SQL 2005 running in it. I need to > connect SQL 2005 from my desk top which was sql client installed in it. > > can any opn pls help me to set the ip / dns settings in vista and VPC. > > > Thanks a ton in advance. > > Regards > Anbu > > > -- > ansur more detail of your setup. How are the two physical machines connected? What network setting are you using on the vm? If the notebook and desktop are connected to the same physical network and set to get their network config from a DHCP server, this should work automatically if the vm is set to use the physical NIC in the host. The SQL server will look like an additional machine on the network to the networking software. |
| Vista Home Premium 32bit | Re: How to connect my virtual Machine from my desktop Thank you Bill. ![]() Well, only one note book ehich act as both desktop and VM. my VM is sitting in e$. Thank You Anbu |
| | Re: How to connect my virtual Machine from my desktop "ansur" <guest@xxxxxx-email.com> wrote in message news:cb1d06225567b595983726f62b15779c@xxxxxx-gateway.com... Quote: > > Thank you Bill. ![]() > > Well, only one note book ehich act as both desktop and VM. > my VM is sitting in e$. > > Thank You > Anbu > > > -- > ansur machine (Virtual Machine Network Services) works with the driver software for the network card in your host machine. If your host is not connected to a network, you need to install a Microsoft Loopback Adapter in the host machine. Look in the help files on the host machine on how to do this. When you have this installed you should see a Loopback Adapter option in the settings for the NIC in your VM. If you select this option, the guest and host can use this network to communicate. |
| | Re: How to connect my virtual Machine from my desktop "Bill Grant" <not.available@xxxxxx> wrote in message news:OXf028MiJHA.5020@xxxxxx Quote: > > > "ansur" <guest@xxxxxx-email.com> wrote in message > news:cb1d06225567b595983726f62b15779c@xxxxxx-gateway.com... Quote: >> >> Thank you Bill. ![]() >> >> Well, only one note book ehich act as both desktop and VM. >> my VM is sitting in e$. >> >> Thank You >> Anbu >> >> >> -- >> ansur > The software for networking between the host machine and the virtual > machine (Virtual Machine Network Services) works with the driver software > for the network card in your host machine. > > If your host is not connected to a network, you need to install a > Microsoft Loopback Adapter in the host machine. Look in the help files on > the host machine on how to do this. When you have this installed you > should see a Loopback Adapter option in the settings for the NIC in your > VM. If you select this option, the guest and host can use this network to > communicate. Hardware Select "Install the hardware that I manually select" Select Network Adapters Select Microsoft Select Microsoft Loopback Adapter |
| | #6 (permalink) |
| Vista Home Premium 32bit | Re: How to connect my virtual Machine from my desktop Thank you bill for your help. I had installed Microsoft Loopback Adapter. but thit havent helped much. Let me explain in detail about my requirement and issue. 1. My notebook OS is vista home premium sp1 with drives c,d,e 2. I had installed virtual PC console 3. my virtual pc files are in e$. having virtual PC for SQL 2005 4. In virtual PC console settings i had configured networking to shared networking for adapter 1. 5. after selecting this i am able to run ipconfig and it is giving IP in virtual PC IP But when i try to ping my laptop it is not able to ping and viceversa i believe i need to do some ip configure in laptop. can you pls advice me on this. Thanks a lot in advance. Regards Anbu |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: How to connect my virtual Machine from my desktop Thank you bill for your help. I had installed Microsoft Loopback Adapter. but thit havent helped much. Let me explain in detail about my requirement and issue. 1. My notebook OS is vista home premium sp1 with drives c,d,e 2. I had installed virtual PC console 3. my virtual pc files are in e$. having virtual PC for SQL 2005 4. In virtual PC console settings i had configured networking to shared networking for adapter 1. 5. after selecting this i am able to run ipconfig and it is giving IP in virtual PC IP : 192.168.131.66 subnet mask : 255.255.255.0 default gateway : 192.168.131.254 But when i try to ping my laptop it is not able to ping and viceversa i believe i need to do some ip configure in laptop. can you pls advice me on this. Thanks a lot in advance. Regards Anbu |
| | #8 (permalink) |
| | Re: How to connect my virtual Machine from my desktop "ansur" <guest@xxxxxx-email.com> wrote in message news:dd4374c3760f6b12450a927f5f8c3438@xxxxxx-gateway.com... Quote: > > Thank you bill for your help. I had installed Microsoft Loopback > Adapter. but thit havent helped much. Let me explain in detail about my > requirement and issue. > > 1. My notebook OS is vista home premium sp1 with drives c,d,e > 2. I had installed virtual PC console > 3. my virtual pc files are in e$. having virtual PC for SQL 2005 > 4. In virtual PC console settings i had configured networking to shared > networking for adapter 1. > 5. after selecting this i am able to run ipconfig and it is giving IP > in virtual PC > IP : 192.168.131.66 > subnet mask : 255.255.255.0 > default gateway : 192.168.131.254 > > But when i try to ping my laptop it is not able to ping and viceversa > > i believe i need to do some ip configure in laptop. can you pls advice > me on this. Thanks a lot in advance. > > Regards > Anbu > > > -- > ansur use the loopback adapter option. You need to manually configure the loopback adapter in the host and the NIC in the vm with IP addresses in the same IP subnet. (eg 192.168.21.1 mask 255.255.255.0 and 192.168.21.2 mask 255.255.255.0). |
| | #9 (permalink) |
| Vista Home Premium 32bit | Re: How to connect my virtual Machine from my desktop Thank you bill for your great help and detailed setup details. now i am able to ping vm from host and reverse and able to access my portal . million thanks for this help. |
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| unable to connect my virtual Machine through Remote Desktop Connec | Virtual PC | |||
| Unable to install Virtual Guest Services on virtual machine | Virtual Server | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
| Moving Virtual Machine from Hyper-v to Virtual Server 2005 | Virtual Server | |||
