Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - How to decrease p4 speed to a 486 level?
Old 02-08-2009   #1 (permalink)
Jack
In my Win3.1 vm, screen savers run extremely fast.
Is there a way to reduce its speed to match an old 486 machine?
Thanks
Jack
Old 02-08-2009   #2 (permalink)
VanguardLH
Re: How to decrease p4 speed to a 486 level?
Um, why are you even running screen savers in any virtual machine?
Obviously they aren't going to save the "screen" from burning in an
image. They don't save power. And the screen saver you are using for
your host OS is what gives you the lockout security for your host.
If you are, say, allowing remote access to the VMs and are somehow
thinking that a screen saver provides security, why are you wasting CPU
cycles running a screen saver that has to compute an ever-changing
screen? Just use the black screen saver. It runs at the same speed all
the time: just a black screen all the time.
During the VM's bootup and hitting Del to go into its BIOS, you will see
there are no settings for changing the clock or multiplier on the CPU.
How do i Decrease Ping? Network & Sharing
Re: Decrease input level of a USB connected microphone Vista General
how to decrease user level? VB Script
strange decrease in WEI Vista performance & maintenance
WEI rating decrease after installing more ram Vista performance & maintenance
