| | moved a vhd from x86 to 64-bit system, is VMA any different withthe 64-bit Virtual PC? I just replaced my desktop with a 64-bit Vista system, and I installed the 64-bit version of Virtual PC 2007+SP1. I plan to run the same virtual machines as I previously ran on a 32-bit system with the x86 version of Virtual PC 2007+SP1. Do I need to update the Virtual Machine Additions? Are they the same in the x86 and 64-bit versions? Thanks, Bob |
| | Re: moved a vhd from x86 to 64-bit system, is VMA any different withthe 64-bit Virtual PC? bobfnospam@xxxxxx wrote: Quote: > I just replaced my desktop with a 64-bit Vista system, and I installed > the 64-bit version of Virtual PC 2007+SP1. I plan to run the same > virtual machines as I previously ran on a 32-bit system with the x86 > version of Virtual PC 2007+SP1. Do I need to update the Virtual Machine > Additions? Are they the same in the x86 and 64-bit versions? I have a dual boot XP x86 and Vista x64 machine, and I can use the same VM's on each. The VM's live on a common data partition used by both OS's. -- David Wilkinson Visual C++ MVP |
| | Re: moved a vhd from x86 to 64-bit system, is VMA any different withthe 64-bit Virtual PC? David Wilkinson wrote: Quote: > bobfnospam@xxxxxx wrote: Quote: >> I just replaced my desktop with a 64-bit Vista system, and I installed >> the 64-bit version of Virtual PC 2007+SP1. I plan to run the same >> virtual machines as I previously ran on a 32-bit system with the x86 >> version of Virtual PC 2007+SP1. Do I need to update the Virtual >> Machine Additions? Are they the same in the x86 and 64-bit versions? > It will work. The additions are installed in the guest. > > I have a dual boot XP x86 and Vista x64 machine, and I can use the same > VM's on each. The VM's live on a common data partition used by both OS's. > However, unlike anything else on the guest, they are obviously aware of the host. I just wanted to make sure. Bob |
| Modifying the Folder Infotip/Tooltip (When hovering a folder withthe cursor) | Vista General | |||
| is there anyway to set on a remote machine "Log On As A Service" withthe SC sdset or other SC command | .NET General | |||
| PLEASE HELP - Can't Get Virtual PC to Install Operating System!!! | Virtual PC | |||
| Updated exe data moved to Virtual Folder | Vista file management | |||
| New operating system in Virtual PC | Virtual PC | |||
