Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - networked printer problem
Old 02-12-2009   #1 (permalink)
-=ed
dell Inspiron 530, quad 2.6ghz, 3gb, XP SP3 32bit, VPC 2007 sp1 XP SP3 guest,
networked
I have a VPC that talks to the internet correctly, and can ping my network,
and my network printer.
I cannot interact with any part of the network except my router [192.168.1.1]
This is not a problem except that I want to print to the networked printer.
I could use some help.
What should I be doing to try to fix this?
-=ed
Old 02-13-2009   #2 (permalink)
Bill Grant
Re: networked printer problem
"-=ed" <ed@xxxxxx> wrote in message
news:710BE066-6AD5-4237-ADD4-A00C212D7989@xxxxxx
> guest,
> networked
> network,
> [192.168.1.1]
> printer.
> -=ed
How is the networking configured? Does the vm get its network config
from DHCP on the router? Is it in the same domain/workgroup as the LAN
machines?
The networking software has no way to tell if your machine is a vm or
not. If it is correctly configured, it will look just like any other machine
on your LAN and use any resources available to the LAN machines.
XP desktop printer networked to VISTA laptop - adding printer error Vista print fax & scan
Networked printer problem Network & Sharing
Problem printing from XP to printer networked on Vista x64 Vista print fax & scan
Vista to Vista networked printer problem Vista networking & sharing
Networked HP Printer Problem Vista print fax & scan
