| | Using hardware-assisted virtualization I just discovered that my Lenovo laptop does have a bios option tu turn on hardware-assisted virtualization (but was disabled). Is there any problems using it? Any negative effects when using it when not running virtualization software? There must be some reason why it is disabled by default. Also how much does it effect performance when running VMs? Marginal or will I really notice any difference? Well guess I will just go and turn it on to see :-). |
| | Re: Using hardware-assisted virtualization Magnusb wrote: Quote: > I just discovered that my Lenovo laptop does have a bios option tu turn > on hardware-assisted virtualization (but was disabled). Is there any > problems using it? Any negative effects when using it when not running > virtualization software? There must be some reason why it is disabled by > default. > > Also how much does it effect performance when running VMs? Marginal or > will I really notice any difference? Well guess I will just go and turn > it on to see :-). http://en.wikipedia.org/wiki/Native_virtualization |
| | Re: Using hardware-assisted virtualization On Fri, 13 Feb 2009 12:48:53 +0100, Magnusb <magnusb@xxxxxx> wrote: Quote: >I just discovered that my Lenovo laptop does have a bios option tu turn >on hardware-assisted virtualization (but was disabled). Is there any >problems using it? Any negative effects when using it when not running >virtualization software? There must be some reason why it is disabled by >default. it is to support, why do you think Dell,Lenovo, etc make custom BIOS with less functionality? Lowers their support costs by giving you less things to mess around with Quote: > >Also how much does it effect performance when running VMs? Marginal or >will I really notice any difference? Well guess I will just go and turn >it on to see :-). there's no difference. Installing a VM, running VMs without Additions (Linux OSes), or without optimization (Win7) you should see a significant and noticable performance increase. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| Why is Hardware Assisted Virtualisation now mandatory? | Virtual PC | |||
| Enabling hardware-assisted virtulisation | Virtual PC | |||
| hardware virtualization | Virtual PC | |||
| Hardware-assisted virtualization | Virtual PC | |||
| Hardware-assisted Virtualization "not available" | Virtual PC | |||
