| | 32-bit machines don't work on 64-bit OS? I just set up a new computer with 64-bit Vista and copied some existing virtual machine files from my old 32-bit XP computer. VPC won't open them, with an error about possibly a "wrong version". Is this a 32-bit/64-bit issue? Or anything that I can fix without rebuilding the virtual machines from scratch? Thanks! -Doug |
| | Re: 32-bit machines don't work on 64-bit OS? "douglasl" <douglasl@xxxxxx> wrote in message news:B3C6C83A-7BEB-47B1-802A-08F37ED0A13F@xxxxxx My guess is it is the VM additions. These are drivers, which would be 32 bit drivers from your old computer, that won't work with your new 64 bit OS. I would try un-installing the VM additions in the 32 bit OS, then try them again in 64 bit Vista. |
| | Re: 32-bit machines don't work on 64-bit OS? On Sun, 15 Feb 2009 19:47:00 -0800, douglasl <douglasl@xxxxxx> wrote: Quote: >I just set up a new computer with 64-bit Vista and copied some existing >virtual machine files from my old 32-bit XP computer. VPC won't open them, >with an error about possibly a "wrong version". > >Is this a 32-bit/64-bit issue? Or anything that I can fix without rebuilding >the virtual machines from scratch? Thanks! > >-Doug you moved them over in a Saved State this will happen. You should be able to delete the saved state file, .vsv and boot the VM then. Otherwise, go back to the original machine, completely shut down (turn off) the VMs and recopy them. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | Re: 32-bit machines don't work on 64-bit OS? Actually the additions are identical between the 64-bit and 32-bit versions of VPC. (The additions only run in the VM and the VM is 32-bit only...) I have no idea why he might be getting a "wrong version" error, I've never seen that. I'd have to see just where he's getting that message and if there is any other text to it. -- Bob Comer On Sun, 15 Feb 2009 23:09:07 -0500, "Bob Campbell" <bob@xxxxxx> wrote: Quote: >"douglasl" <douglasl@xxxxxx> wrote in message >news:B3C6C83A-7BEB-47B1-802A-08F37ED0A13F@xxxxxx > >My guess is it is the VM additions. These are drivers, which would be 32 >bit drivers from your old computer, that won't work with your new 64 bit OS. >I would try un-installing the VM additions in the 32 bit OS, then try them >again in 64 bit Vista. |
| | Re: 32-bit machines don't work on 64-bit OS? "Robert Comer" <bobcomer-removeme-@xxxxxx> wrote in message news:3uphp4tnuqohuoo5384efp39dv1hs5ulrd@xxxxxx Quote: > Actually the additions are identical between the 64-bit and 32-bit > versions of VPC. (The additions only run in the VM and the VM is > 32-bit only...) But yeah, now that you mention it, that makes sense. Nevermind! |
| | #6 (permalink) |
| | Re: 32-bit machines don't work on 64-bit OS? "douglasl" <douglasl@xxxxxx> wrote in message news:B3C6C83A-7BEB-47B1-802A-08F37ED0A13F@xxxxxx Quote: >I just set up a new computer with 64-bit Vista and copied some existing > virtual machine files from my old 32-bit XP computer. VPC won't open them, > with an error about possibly a "wrong version". > > Is this a 32-bit/64-bit issue? Or anything that I can fix without > rebuilding > the virtual machines from scratch? Thanks! i.e. didn't leave them in a saved state? 2) Did you have VPC 2004 or 2007 on the XP host? 3) On the Vista host machine, did you definitely install the version of VPC 2007 SP1 specifically targeted at 64-bit hosts? 4) Is the CPU on the Vista host machine substantially different from the CPU on the XP host machine i.e. AMD etc...? -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #7 (permalink) |
| | Re: 32-bit machines don't work on 64-bit OS? No prob. <g> I think Steve has it right, the saved state issue. No way to go across machines like that. -- Bob Comer On Sun, 15 Feb 2009 23:31:31 -0500, "Bob Campbell" <bob@xxxxxx> wrote: Quote: >"Robert Comer" <bobcomer-removeme-@xxxxxx> wrote in message >news:3uphp4tnuqohuoo5384efp39dv1hs5ulrd@xxxxxx Quote: >> Actually the additions are identical between the 64-bit and 32-bit >> versions of VPC. (The additions only run in the VM and the VM is >> 32-bit only...) >Well, like I said, I was guessing! :-) > >But yeah, now that you mention it, that makes sense. > >Nevermind! > |
| | #8 (permalink) |
| | Re: 32-bit machines don't work on 64-bit OS? "Bob Campbell" <bob@xxxxxx> wrote in message news:ZYSdnccpSaZ3ewXUnZ2dnUVZ_uWdnZ2d@xxxxxx Quote: > My guess is it is the VM additions. These are drivers, which would be 32 > bit drivers from your old computer, that won't work with your new 64 bit > OS. I would try un-installing the VM additions in the 32 bit OS, then try > them again in 64 bit Vista. and, as such, can only ever be 32-bit - the host OS is irrelevant... If Steve's thought about the guests being in saved state and not shut down properly is not the problem, then the only other thing I can think of is that the CPU on the Vista host is substantially different from that on the XP host - I've known that to cause issues in the past, but I don't recall ever seeing a message complaining of a wrong version... -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #9 (permalink) |
| | Re: 32-bit machines don't work on 64-bit OS? I'm sure it's the Saved State issue, although I can't go fix it right this instant. In fact I think the error message hinted at that possibility, but I was too frazzled to put 2 + 2 together. The pressure of moving the Significant Other's entire home-based business to a new computer, to a recurring chorus of "I KNOW something's not going to work!", had overwhelmed me. :-) Thanks! -Doug |
| | #10 (permalink) |
| | Re: 32-bit machines don't work on 64-bit OS? On Mon, 16 Feb 2009 06:32:02 -0800, douglasl <douglasl@xxxxxx> wrote: Quote: >I'm sure it's the Saved State issue, although I can't go fix it right this >instant. In fact I think the error message hinted at that possibility, but I >was too frazzled to put 2 + 2 together. > >The pressure of moving the Significant Other's entire home-based business to >a new computer, to a recurring chorus of "I KNOW something's not going to >work!", had overwhelmed me. :-) > and then start the guest. It would be as if you had pulled the power line on the running machine, no more. But if you are using undo disks, then maybe these are not compatible and in this case you should be more careful because if you erase the associated vud file you lose everything since the last commit you have done.... -- Bo Berglund (Sweden) |
| using a VM on 2 different machines | Virtual PC | |||
| Windows firewall doesnt work when I add vista machines to the doma | Vista security | |||
| I can see my XP machines, and my XP machines can see my Vista Mach | Vista networking & sharing | |||
