| | Fixed to expanding hard drive or add another hard drive? I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of space on that drive. I would appreciate pros and cons on whether I should convert the fixed drive to an dynamic expanding one or should I add a second virtual disk and if I do that does it need to be fixed like the current one? |
| | Re: Fixed to expanding hard drive or add another hard drive? "Melelina" <melelina@xxxxxx> wrote in message news:eSTS8CCkJHA.1388@xxxxxx Quote: >I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of >space on that drive. I would appreciate pros and cons on whether I should >convert the fixed drive to an dynamic expanding one or should I add a >second virtual disk and if I do that does it need to be fixed like the >current one? I'd use the dynamic expanding option and simply set the size for the maximum you think you may eventually need. No harm in making your estimate on the high side...as it will only expand to what is actually needed. |
| | Re: Fixed to expanding hard drive or add another hard drive? "philo" <philo@xxxxxx> wrote in message news:OQjGiEQkJHA.3380@xxxxxx Quote: > > "Melelina" <melelina@xxxxxx> wrote in message > news:eSTS8CCkJHA.1388@xxxxxx Quote: >>I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of >>space on that drive. I would appreciate pros and cons on whether I should >>convert the fixed drive to an dynamic expanding one or should I add a >>second virtual disk and if I do that does it need to be fixed like the >>current one? > > > > > I'd use the dynamic expanding option > and simply set the size for the maximum you think you may eventually need. > No harm in making your estimate on the high side...as it will only expand > to what is actually needed. > Hmmm....I can't copy/past from the help file. I wonder why? Anyhow, the help file says that before converting to an expanding disk, I need to use a third party disk utility to zero out the blank spaces. I don't know what that means. Then it says that after I do this, I need to compact the disk. This is while it is still a fixed size disk. Then the Help file appears to contradict itself when I look at the Compact a virtual Hard Disk section. There it says that the compaction option is available ONLY for expanding disks. Huh? Earlier it says under Create a Dynamically Expanding Disk from a Fixed Size disk that I am supposed to compact the disk after using a third party software to zero out the blank spaces and it says I am supposed to compact the disk while it is still a fixed disk BEFORE converting it. That is all very confusing. Plus, I don't know what zeroing out blank spaces means. |
| | Re: Fixed to expanding hard drive or add another hard drive? On Tue, 17 Feb 2009 03:40:50 -1000, "Melelina" <melelina@xxxxxx> wrote: Quote: > >"philo" <philo@xxxxxx> wrote in message >news:OQjGiEQkJHA.3380@xxxxxx Quote: >> >> "Melelina" <melelina@xxxxxx> wrote in message >> news:eSTS8CCkJHA.1388@xxxxxx Quote: >>>I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of >>>space on that drive. I would appreciate pros and cons on whether I should >>>convert the fixed drive to an dynamic expanding one or should I add a >>>second virtual disk and if I do that does it need to be fixed like the >>>current one? >> >> >> >> >> I'd use the dynamic expanding option >> and simply set the size for the maximum you think you may eventually need. >> No harm in making your estimate on the high side...as it will only expand >> to what is actually needed. >> > >Hmmm....I can't copy/past from the help file. I wonder why? Anyhow, the >help file says that before converting to an expanding disk, I need to use a >third party disk utility to zero out the blank spaces. I don't know what >that means. Then it says that after I do this, I need to compact the disk. >This is while it is still a fixed size disk. > >Then the Help file appears to contradict itself when I look at the Compact a >virtual Hard Disk section. There it says that the compaction option is >available ONLY for expanding disks. Huh? Earlier it says under Create a >Dynamically Expanding Disk from a Fixed Size disk that I am supposed to >compact the disk after using a third party software to zero out the blank >spaces and it says I am supposed to compact the disk while it is still a >fixed disk BEFORE converting it. > >That is all very confusing. Plus, I don't know what zeroing out blank spaces >means. > 1) Use VHDResizer to move your old vhd disk data into a new fresh dynamically expanding disk set to a really large size. At the end you need to expand the new VHD partition (because it will be a same-sized partition plus lots of unused space). You can do this according to a description in this link: http://kb.dutchalps.com/microsoftvirtualpc.htm 2) Create a new empty virtual disk using the virtual disk wizard. Then attach this to the guest you want to expand the disk of. Then boot up the guest and use whatever disk imaging software you have access to to copy your boot disk image to the now available new and empty disk. I have done this using both Norton Ghost 2003 and Acronis Workstation products. Ghost 2003 works well for operating systems below Vista, but has trouble with Vista. Acronis handles Vista too just fine. These products will allow expanding the data into the full disk sized partition at imaging time so after you are done, just shut down the guest and in the guest settings change the virtual disks (disable disk #2 and set the new disk as disk #1) DONE -- Bo Berglund (Sweden) |
| | Re: Fixed to expanding hard drive or add another hard drive? On Mon, 16 Feb 2009 00:24:20 -1000, "Melelina" <melelina@xxxxxx> wrote: Quote: >I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of >space on that drive. I would appreciate pros and cons on whether I should >convert the fixed drive to an dynamic expanding one or should I add a second >virtual disk and if I do that does it need to be fixed like the current one? > help. You've already set the maximum size of the disk. A dynamically expanding disk only expands to it's maximum size. Example: if your fixed disk is 20GB, converting it to a dyn disk will simply make it a dyn disk with a 20GB expansion limit. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | #6 (permalink) |
| | Re: Fixed to expanding hard drive or add another hard drive? "Bo Berglund" <boberglund@xxxxxx> wrote in message news:s9plp4lfadhce9ds7mmj3vl4ij5ngp435h@xxxxxx Quote: > On Tue, 17 Feb 2009 03:40:50 -1000, "Melelina" <melelina@xxxxxx> > wrote: > Quote: >> >>"philo" <philo@xxxxxx> wrote in message >>news:OQjGiEQkJHA.3380@xxxxxx Quote: >>> >>> "Melelina" <melelina@xxxxxx> wrote in message >>> news:eSTS8CCkJHA.1388@xxxxxx >>>>I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out >>>>of >>>>space on that drive. I would appreciate pros and cons on whether I >>>>should >>>>convert the fixed drive to an dynamic expanding one or should I add a >>>>second virtual disk and if I do that does it need to be fixed like the >>>>current one? >>> >>> >>> >>> >>> >>> I'd use the dynamic expanding option >>> and simply set the size for the maximum you think you may eventually >>> need. >>> No harm in making your estimate on the high side...as it will only >>> expand >>> to what is actually needed. >>> >> >>Hmmm....I can't copy/past from the help file. I wonder why? Anyhow, the >>help file says that before converting to an expanding disk, I need to use >>a >>third party disk utility to zero out the blank spaces. I don't know what >>that means. Then it says that after I do this, I need to compact the disk. >>This is while it is still a fixed size disk. >> >>Then the Help file appears to contradict itself when I look at the Compact >>a >>virtual Hard Disk section. There it says that the compaction option is >>available ONLY for expanding disks. Huh? Earlier it says under Create a >>Dynamically Expanding Disk from a Fixed Size disk that I am supposed to >>compact the disk after using a third party software to zero out the blank >>spaces and it says I am supposed to compact the disk while it is still a >>fixed disk BEFORE converting it. >> >>That is all very confusing. Plus, I don't know what zeroing out blank >>spaces >>means. >> > In your case I'd do one of two things: > > 1) Use VHDResizer to move your old vhd disk data into a new fresh > dynamically expanding disk set to a really large size. > At the end you need to expand the new VHD partition (because it will > be a same-sized partition plus lots of unused space). You can do this > according to a description in this link: > http://kb.dutchalps.com/microsoftvirtualpc.htm > > 2) Create a new empty virtual disk using the virtual disk wizard. > Then attach this to the guest you want to expand the disk of. > Then boot up the guest and use whatever disk imaging software you have > access to to copy your boot disk image to the now available new and > empty disk. I have done this using both Norton Ghost 2003 and Acronis > Workstation products. Ghost 2003 works well for operating systems > below Vista, but has trouble with Vista. Acronis handles Vista too > just fine. > These products will allow expanding the data into the full disk sized > partition at imaging time so after you are done, just shut down the > guest and in the guest settings change the virtual disks (disable disk > #2 and set the new disk as disk #1) > DONE think the only thing it lacks the ability to do incremental images). But I will look into your first suggestion also. Thank you. Quote: > > -- > > Bo Berglund (Sweden) |
| | #7 (permalink) |
| | Re: Fixed to expanding hard drive or add another hard drive? "Steve Jain [MVP]" <noreply.-@-.essjae.com> wrote in message news:gr2mp4hf4pcrei9itqu857tqbqnu4pq778@xxxxxx Quote: > On Mon, 16 Feb 2009 00:24:20 -1000, "Melelina" <melelina@xxxxxx> > wrote: > Quote: >>I have Vista Ultimate on VPC and one fixed virtual hard drive. I am out of >>space on that drive. I would appreciate pros and cons on whether I should >>convert the fixed drive to an dynamic expanding one or should I add a >>second >>virtual disk and if I do that does it need to be fixed like the current >>one? >> > Simply converting to a dynamically expanding drive isn't going to > help. You've already set the maximum size of the disk. A dynamically > expanding disk only expands to it's maximum size. > Example: if your fixed disk is 20GB, converting it to a dyn disk will > simply make it a dyn disk with a 20GB expansion limit. VMWare Workstation tells you to do a fixed disk rather than dynamic. But I thought that on both softwares that dynamic would expand without any limit. I sure have been confused about that! So, wouldn't the easiest thing be to just add another virtual drive? Quote: |
| | #8 (permalink) |
| | Re: Fixed to expanding hard drive or add another hard drive? "Melelina" <melelina@xxxxxx> wrote in message news:%23a5ugcbkJHA.4696@xxxxxx Quote: > I didn't realize that. Why does VPC use an expanding disk by default then? Creating a 60GB fixed hard disk will create a 60GB vhd on the host straightaway. Creating a 60GB dynamic hard disk will not create a 60GB vhd on the host, but it will create a vhd on the host which has the capacity to grow up to 60GB - when it's first created, it will only take up about 3K on the host. -- Mark Rae ASP.NET MVP http://www.markrae.net |
| Hard drive light constantly flashing ,reading hard drive during id | Vista hardware & devices | |||
| Transfering from XP hard drive to vista Hard drive | Vista General | |||
| No online media available on new hard drive - old hard drive had l | Vista music pictures video | |||
| Crashed hard drive...copied hard drive but can't access User area | Vista General | |||
| Transferring files from Slave XP hard drive to new Vista Hard drive - primary | Vista installation & setup | |||
