| | VMs wont start after changing primary monitor Hello, I had a couple of VMs running when i switched my primary and secondary monitors on the host computer. After applying, the already running VMs show blank screen or are stuck at the last display screen. If i start another VM which was not running during the display switch, it would start the BIOS check and nothing shows up after. I switched the primary and secondary monitors to the way it was and things are fine. Any ideas? TIA Priyesh |
| Primary Monitor will not always come out of sleep mode. | General Discussion | |||
| Set primary display (monitor) | PowerShell | |||
| Primary display switches to external monitor | Vista hardware & devices | |||
| Primary Monitor switching | Vista hardware & devices | |||
| Please read, cross post: dim primary monitor | Vista hardware & devices | |||
