Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - USB Ports Problem.
Old 03-03-2009   #1 (permalink)
idspence
USB Ports Problem.
I am trying to set up my Logitec MOMO Racing Weel on a windows 98 on Virtual
pc. While i was installing the drivers on 98 virtual, in the background I
got a message on vista saying Logitec MOMO blahblahblah... So to sum it all
up. The USB Ports on my computer works for Vista and not the 98 on virtual
PC...
But.
I can get a very small amount of control when I use the conntroller on 98
but it is very un-even.
Old 03-03-2009   #2 (permalink)
Bo Berglund
Re: USB Ports Problem.
On Mon, 2 Mar 2009 21:10:00 -0800, idspence
>PC...
>But.
You won't be able to use any USB device inside a VPC2007 virtual
machine because the USB subsystem is not emulated in the guest....
The only way USB devices are accessible is if they are a keyboard or a
mouse, in which case they are emulated as PS/2 devices and if they are
pure storage devices appearing as drive letters on the host. In that
case you can use network sharting from the host to the guest. But tha
is not using USB in the guest because that is impossible.
Look at VMWare instead....
Bo Berglund (Sweden)
Old 03-03-2009   #3 (permalink)
David B.
It's not a problem, a simple search would reveal to you that VirtualPC does
not support USB.
Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm
How to ask a question http://support.microsoft.com/kb/555375
"idspence" <idspence@xxxxxx> wrote in message
news:7402B323-8783-4F75-8C0C-2D3522D51F39@xxxxxx
>Virtual
> all
> virtual
> PC...
> But.
Old 03-03-2009   #4 (permalink)
Mark Rae [MVP]
> PC...
That's correct - Virtual PC doesn't emulate the USB subsystem.
If need that functionality in a virtual machine, you'll need to use
different virtualisation software e.g. VMWare...
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 03-03-2009   #5 (permalink)
idspence
okay I will try to use VMware Workstation. if it works I will reply.. Thnaks
Old 03-04-2009   #6 (permalink)
Bo Berglund
On Tue, 3 Mar 2009 18:57:01 -0800, idspence
No need. It *will* work! I use it all the time when I must handle USB
devices.
Also VMWare Player 2 has USB support but you will have problems
creating a VM with Player....
Old 03-04-2009   #7 (permalink)
Robert Riebisch
Really? I simply create VM configuration files using Notepad and VMDKs
using qemu-img.exe. ;-)
Robert Riebisch
Bitte NUR in der Newsgroup antworten!
Please reply to the Newsgroup ONLY!
Old 03-05-2009   #8 (permalink)
ronald.phillips
On Mar 4, 4:39*pm, Bo Berglund <bobergl...@xxxxxx> wrote:
> <idspe...@xxxxxx> wrote:
Quote:
> >okay I will try to use VMware Workstation. *if it works I will reply..*Thnaks
> devices.
or just use the webpage: http://www.easyvmx.com/
Old 03-05-2009   #9 (permalink)
Robert Riebisch
ronald.phillips@xxxxxx wrote:
Or http://vmmanager.sourceforge.net/
Robert Riebisch
Old 03-09-2009   #10 (permalink)
jorgensen
RE: USB Ports Problem.
"idspence" wrote:
Have tried it on VirtualBox and the system goes bananas because it is not
possible to properly share an USB connection synchronous.
Key Ports Problem Live Messenger
I Can only Access HTTPS and Other Ports, Internet Port 80 Problem Browsers & Mail
Problem with new USB ports. Drivers
usb ports problem on vista Vista General
Problem with USB-ports and Bluetooth Vista hardware & devices
