| | Using National Instruments Hardware With Virtual PC Please can anyone help? I have some legacy software that runs on Windows 98 and uses a National Instruments data acquisition card. The card plugs into a PCMCIA slot and has appropriate drivers for Windows 98. Does anyone know if this will work using Virtual PC? Thanks. |
| | Re: Using National Instruments Hardware With Virtual PC There's no way to do that with VPC, it only emulates a certain set of hardware and can't be expanded. None of the virtualization solutions will work for this, you'll have to run it on real hardware. -- Bob Comer On Tue, 3 Mar 2009 01:50:03 -0800, Dazed and Confused <Dazed and Confused@xxxxxx> wrote: Quote: >Please can anyone help? > >I have some legacy software that runs on Windows 98 and uses a National >Instruments data acquisition card. > >The card plugs into a PCMCIA slot and has appropriate drivers for Windows 98. > >Does anyone know if this will work using Virtual PC? > >Thanks. |
| | Re: Using National Instruments Hardware With Virtual PC "Dazed and Confused" <Dazed and Confused@xxxxxx> wrote in message news:1CF36290-18D1-4F31-A39A-696D2D6585A4@xxxxxx Quote: > I have some legacy software that runs on Windows 98 and uses a National > Instruments data acquisition card. > > The card plugs into a PCMCIA slot and has appropriate drivers for Windows > 98. > > Does anyone know if this will work using Virtual PC? Virtual PC, VMWare / Virtual Box etc all emulate a specific set of hardware which cannot be changed: http://vpc.visualwin.com/ngfaq.aspx#8 -- Mark Rae ASP.NET MVP http://www.markrae.net |
| Windows Virtual PC and Hardware Virtualization | Virtual PC | |||
| national instruments shared has stopped working | General Discussion | |||
| CPU hardware virtual server. | Virtual Server | |||
| National Instruments LabView 8.5 Works | Software | |||
| New York Teen Entrepreneurs Win National Urban League-Microsoft National Youth IT Challenge | Vista News | |||
