| | RE: big problems with running virtual pc under dell inspiron 9400 Quote: > I have problems with running virtual pc under dell inspiron 9400. > > 1. Big letency on mouse click responde to file explorer > 2. virtual pc crash with blue screen > 3. files and folders are misplaced on mouse click or drag and drop operation > 4. big latency in responce to keyboard > > I could not find source of problems. > Try to disable network, audio but did not help. > > Does somebody solve this problems? > Running Microsoft Virtual PC in Windows XP Sp3.. 1) SET SHARED NAT, and REBOOT THE VIRTUAL MACHINE, go to start menu then restart. ...selecting your wireless network adapter itself doesn't seem to work. At least on Dell inspiron 6400, you will see an Intel Based Adapter.. Which means if you really wanted you could use that registry method.. And maybe add the NetworkAddress registry key value or whatever.. To allow it to pickup a proper Mac address. Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com |
| | Re: big problems with running virtual pc under dell inspiron 9400 On Sat, 14 Mar 2009 23:09:54 GMT, "Xsouldeath"<zerounderscore@xxxxxx> wrote: Quote: > Quote: >> I have problems with running virtual pc under dell inspiron 9400. >> >> 1. Big letency on mouse click responde to file explorer >> 2. virtual pc crash with blue screen >> 3. files and folders are misplaced on mouse click or drag and drop operation >> 4. big latency in responce to keyboard >> >> I could not find source of problems. >> Try to disable network, audio but did not help. >> >> Does somebody solve this problems? >> >OKAY. > >Running Microsoft Virtual PC in Windows XP Sp3.. > >1) SET SHARED NAT, and REBOOT THE VIRTUAL MACHINE, go to start menu then restart. > >..selecting your wireless network adapter itself doesn't seem to work. > >At least on Dell inspiron 6400, you will see an Intel Based Adapter.. >Which means if you really wanted you could use that registry method.. >And maybe add the NetworkAddress registry key value or whatever.. To allow it to pickup a proper Mac address. > overkill? Most probably the poster who had the problem has long since moved on and is not watching anymore.... -- Bo Berglund (Sweden) |
| Virtual PC 2007 Problems on new Dell Vostro | Vista General | |||
| Upgraded Dell 9400 with Intel 3945 Dual Band Wireless failure | Vista networking & sharing | |||
| Bluetooth kb & mouse on a new Inspiron 9400 laptop | Vista hardware & devices | |||
| missing driver for a built in DELL 9400 nVidia GeForce Go 7800 | Vista hardware & devices | |||
| Dell Inspiron 9400 - Dell 1390 wireless card | Vista hardware & devices | |||
