| | Need advice on using Virtual PC 2007 SP2 I am completely new to Virtual machines. Can someone help please? My host will be Win XP SP3 on a C2D E4400, @ 1 GHz, 2GB RAM (a standalone PC not connected to any LAN) I need the Virtual PC to primarily to port fairly large applications software (written in the DOS days) to Java. I need to create a virtual machine to run Win 98SE or DOS. My questions are 1) Which should I go for ? a) Microsoft Virtual Server 2005 R2 SP1 - Enterprise Edition b) Virtual PC 2007/2007 SP1 2) I need to share some resources of the Host such as the Printer, and DVD Burner. Also I need to be able to copy/transfer files to and from the Host to the Guest (by a shared folder or otherwise). 3) I need limited Internet connectivity for the Guest but via the firewall of the host, as I don’t know of any decent free firewall for win 98SE. I will be using the Host to regularly connect to internet (Broadband), but need my guest to be hidden/shielded from the internet (unless I explicitly was it to connect to the internet) 4) What kind of connectivity between Host and Guest should I go for ? a) Shared Networking (NAT) b) Network adapter on the physical computer c) Microsoft Loopback Adapter |
| | Re: Need advice on using Virtual PC 2007 SP2 >1) Which should I go for ? Quote: > a) Microsoft Virtual Server 2005 R2 SP1 - Enterprise Edition > b) Virtual PC 2007/2007 SP1 Quote: >2) I need to share some resources of the Host such as the Printer, and DVD >Burner. Also I need to be able to copy/transfer files to and from the Host to >the Guest (by a shared folder or otherwise). Shared folders are doable though. As for the printer, it depends on what kind, but you might have to use networking to use it. Quote: >3) I need limited Internet connectivity for the Guest but via the firewall >of the host, as I don’t know of any decent free firewall for win 98SE. I will >be using the Host to regularly connect to internet (Broadband), but need my >guest to be hidden/shielded from the internet (unless I explicitly was it to >connect to the internet) > >4) What kind of connectivity between Host and Guest should I go for ? > a) Shared Networking (NAT) > b) Network adapter on the physical computer > c) Microsoft Loopback Adapter hosts firewall like that, but in using (Shared Networking (NAT), you can't get to the VM from outside, which is I think what you want. -- Bob Comer On Sun, 15 Mar 2009 10:39:01 -0700, ravi <ravi@xxxxxx> wrote: Quote: >I am completely new to Virtual machines. Can someone help please? > >My host will be Win XP SP3 on a C2D E4400, @ 1 GHz, 2GB RAM (a standalone PC >not connected to any LAN) > >I need the Virtual PC to primarily to port fairly large applications >software (written in the DOS days) to Java. I need to create a virtual >machine to run Win 98SE or DOS. > >My questions are > >1) Which should I go for ? > a) Microsoft Virtual Server 2005 R2 SP1 - Enterprise Edition > b) Virtual PC 2007/2007 SP1 > >2) I need to share some resources of the Host such as the Printer, and DVD >Burner. Also I need to be able to copy/transfer files to and from the Host to >the Guest (by a shared folder or otherwise). > >3) I need limited Internet connectivity for the Guest but via the firewall >of the host, as I don’t know of any decent free firewall for win 98SE. I will >be using the Host to regularly connect to internet (Broadband), but need my >guest to be hidden/shielded from the internet (unless I explicitly was it to >connect to the internet) > >4) What kind of connectivity between Host and Guest should I go for ? > a) Shared Networking (NAT) > b) Network adapter on the physical computer > c) Microsoft Loopback Adapter |
| | RE: Need advice on using Virtual PC 2007 SP2 Virtual PC 2007 is the right platform for you. Forget DOS as it pain to install. I have a DOS/Win311 installation, and it has taken a long time to get it running with TCP networking, extended video and sound - Win98 just installs with everything. Forget burning from a virtual machine, but share the folders to the host and burn from there. With Win98 and the installed extensions, you can drag files between the host and virtual machines with the file explorer. Copy and paste also works between the host and virtual machines. For the printer you need to network share the host printer. Regards networking the virtual machine it gets its own IP address, or you assign it, on your current network, and it works just like another computer on the physical network. Virtual PC installs a driver to the network adapter properties for sharing the adapter, and if you have more adapters, you can choose which ones to use. Don't think you need a firewall, but the old free Sygate firewall should do the job. |
| | RE: Need advice on using Virtual PC 2007 SP2 Thank you both, Bob Comer and Jorgensen. I have installed VPC 2007 SP1, and Win 98SE, and have been able to create/configure sharing of a Host folder. Since Win 98SE has DOS mode, I don’t really need a VM for DOS. Also it seems logical that in the NAT option, since the connection is through the Host, the firewall and antivirus sw on the Host will be effective. The next questions are a) If I use NAT, do I need the Win 98SE Patch Q243199 which is now kb243199, or does the XP SP3 Host and VPC environment cover that. http://support.microsoft.com/kb/243199 b) If I use the ‘Network adapter on the physical computer’, then the VPC will act like a physical pc. So I presume it will have to have its own virus protection and firewall. But will the above patch be required? "jorgensen" wrote: Quote: > Virtual PC 2007 is the right platform for you. > Forget DOS as it pain to install. I have a DOS/Win311 installation, and it > has taken a long time to get it running with TCP networking, extended video > and sound - Win98 just installs with everything. > Forget burning from a virtual machine, but share the folders to the host and > burn from there. > With Win98 and the installed extensions, you can drag files between the host > and virtual machines with the file explorer. Copy and paste also works > between the host and virtual machines. > For the printer you need to network share the host printer. > Regards networking the virtual machine it gets its own IP address, or you > assign it, on your current network, and it works just like another computer > on the physical network. Virtual PC installs a driver to the network adapter > properties for sharing the adapter, and if you have more adapters, you can > choose which ones to use. > Don't think you need a firewall, but the old free Sygate firewall should do > the job. > |
| | RE: Need advice on using Virtual PC 2007 SP2 > Also it seems logical that in the NAT option, since the connection is Quote: > through the Host, the firewall and antivirus sw on the Host will be effective. with the firewall, but not worth it. You might use static addressing and leave gateway and DNS empty for a pretty good security. The antivirus program will not be effective in the virtual machine. You have to scan the shared folders for checking. I now and then take a copy of the virtual harddisk file (xxx.vhd), and if something goes wrong, I always have a full copy of a working session. You can also make a virtual disk for data, and make regular backups of that file. Quote: > a) If I use NAT, do I need the Win 98SE Patch Q243199 which is now kb243199, turned on. |
| | #6 (permalink) |
| | Re: Need advice on using Virtual PC 2007 SP2 >Also it seems logical that in the NAT option, since the connection is Quote: >through the Host, the firewall and antivirus sw on the Host will be effective. all or nothing type thing, it only sees the VM as a whole, so you don't have the granular control that you have on the host. NAT itself protects the VM from outside attack just as well. (So no problem) Quote: >a) If I use NAT, do I need the Win 98SE Patch Q243199 which is now kb243199, >or does the XP >SP3 Host and VPC environment cover that. >http://support.microsoft.com/kb/243199 have the problem as described. Quote: >b) If I use the ‘Network adapter on the physical computer’, then the VPC >will act like a physical pc. So I presume it will have to have its own virus >protection and firewall. protection solution if it can access the internet. As for firewall, that depends on your connection method. Quote: >But will the above patch be required? -- Bob Comer On Mon, 16 Mar 2009 02:16:02 -0700, ravi <ravi@xxxxxx> wrote: Quote: >Thank you both, Bob Comer and Jorgensen. > >I have installed VPC 2007 SP1, and Win 98SE, and have been able to >create/configure sharing of a Host folder. Since Win 98SE has DOS mode, I >don’t really need a VM for DOS. > >Also it seems logical that in the NAT option, since the connection is >through the Host, the firewall and antivirus sw on the Host will be effective. > >The next questions are > >a) If I use NAT, do I need the Win 98SE Patch Q243199 which is now kb243199, >or does the XP >SP3 Host and VPC environment cover that. >http://support.microsoft.com/kb/243199 > >b) If I use the ‘Network adapter on the physical computer’, then the VPC >will act like a physical pc. So I presume it will have to have its own virus >protection and firewall. But will the above patch be required? > > >"jorgensen" wrote: > Quote: >> Virtual PC 2007 is the right platform for you. >> Forget DOS as it pain to install. I have a DOS/Win311 installation, and it >> has taken a long time to get it running with TCP networking, extended video >> and sound - Win98 just installs with everything. >> Forget burning from a virtual machine, but share the folders to the host and >> burn from there. >> With Win98 and the installed extensions, you can drag files between the host >> and virtual machines with the file explorer. Copy and paste also works >> between the host and virtual machines. >> For the printer you need to network share the host printer. >> Regards networking the virtual machine it gets its own IP address, or you >> assign it, on your current network, and it works just like another computer >> on the physical network. Virtual PC installs a driver to the network adapter >> properties for sharing the adapter, and if you have more adapters, you can >> choose which ones to use. >> Don't think you need a firewall, but the old free Sygate firewall should do >> the job. >> |
| | #7 (permalink) |
| | Re: Need advice on using Virtual PC 2007 SP2 Thank you, Sergei. That is exactly what I need. "Sergei Zhirikov" wrote: Quote: Quote: Quote: > >> 3) I need limited Internet connectivity for the Guest but via the firewall > >> of the host, as I don’t know of any decent free firewall for win 98SE. I will > >> be using the Host to regularly connect to internet (Broadband), but need my > >> guest to be hidden/shielded from the internet (unless I explicitly was it to > >> connect to the internet) > >> > >> 4) What kind of connectivity between Host and Guest should I go for ? > >> a) Shared Networking (NAT) > >> b) Network adapter on the physical computer > >> c) Microsoft Loopback Adapter > > None of the VM solutions have the ability to be totally behind the > > hosts firewall like that, but in using (Shared Networking (NAT), you > > can't get to the VM from outside, which is I think what you want. > > > just a matter of network setup, considering that the word "firewall" > used to have a broader meaning than just "Windows Firewall" ;-). I have > similar requirements that the VMs have very limited internet > connectivity. Here is how I achieve that: > > I use "Microsoft Loopback Adapter" for the virtual network and disable > IP forwarding (a.k.a. "Internet Connection Sharing") on the host. This > way the virtual network is completely isolated from the outside world. > In order to provide limited internet connectivity to the VMs (when > necessary) I run HTTP proxy on the host. This way I can fine tune what > hosts and ports on the internet the VMs are able to connect to. > > Hope this helps. > -- > Sergei. > |
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Virtual PC 2007 / Virtual Server 2005 R2 Capabilities | Virtual PC | |||
| Virtual Memory Advice for Vista 64 & 8GB of Ram | Vista performance & maintenance | |||
| Advice on setting up a virtual collaborative environment | Virtual PC | |||
| Installation failures on Virtual PC 2004 and Virtual PC 2007 | Vista installation & setup | |||
