| | VPN problem - Using 2 virtual network cards? I am using VPN (Nortel) to access corporate network. This is working fine, but I have one problem which is not a VPC problem but how the VPN client works. When I use VPN I can't access any local network resources including the host PC and my host PC can't access the guest VM (ie using networking). Can't even ping I can of course use shared drives to access files on my host but I want to have full local network access to/from guest. I am neither an expert on VPN clients or networking in general. Maybe it can be solved in some other way, but wouldn't one solution be to have two virtual network cards. One for normal network card (bridged networking) which is bound to the vpn client and another (probably using NAT or local). Could that be a solution or do you have any other suggestions? |
| | Re: VPN problem - Using 2 virtual network cards? On Wed, 18 Mar 2009 10:26:27 +0100, Magnusb <magnusb@xxxxxx> wrote: Quote: >I am using VPN (Nortel) to access corporate network. This is working >fine, but I have one problem which is not a VPC problem but how the VPN >client works. > >When I use VPN I can't access any local network resources including the >host PC and my host PC can't access the guest VM (ie using networking). >Can't even ping I can of course use shared drives to access files on my >host but I want to have full local network access to/from guest. > >I am neither an expert on VPN clients or networking in general. Maybe it >can be solved in some other way, but wouldn't one solution be to have >two virtual network cards. One for normal network card (bridged >networking) which is bound to the vpn client and another (probably using >NAT or local). > >Could that be a solution or do you have any other suggestions? What it is all about is the *security* of the network you are VPN-ing into. Your VPN client is probably working just like my Cisco VPN in that it effectively disconnects your PC *totally* from its own network neighborhood when the VPN tunnel is established and instead moves it over into the remote network. Whilst the tunnel is up there will be *no* connection between the two networks through the client PC. I believe this is by design for secure VPN clients. If you instead used Microsofts not-so-secure PPTP VPN protocol, then it is possible to configure the PC such that it sees the remote network as an *additional* network and therefore it can access both. But corporate IT departments generally loathe this solution since it effectively compromises their carefully protected network. -- Bo Berglund (Sweden) |
| virtual machine 2007 network problem | Virtual PC | |||
| Virtual PC cannot see network cards (Virtual Server Too) | Virtual PC | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
| problem in connecting two virtual machines for local network only | Virtual PC | |||
| Compatibility issues between Vista and Citibank virtual credit cards | Vista security | |||
