| | Routing problems with Virtual PC I have setup 2 test enviornments which consists of Windows 2003 virtual pc and an XP virtual pc on network 1 and Small Business server virtual pc and an XP virtual pc on network 2. The network configurations are as follows. From XPvirtual pc1, I can ping both NICs on Win2003 but not the host (192.168.1.66). From XPvirtual pc2 I can ping the host (192.168.1.66) IP but not from the host back. I have setup RRAS the same on both servers but am getting different results. Ultimately I am looking to test the servers as routers to/from the 192.168.1.0 network. Any help is appreciated. Host : 192.168.1.66 255.255.255.0 192.168.1.1 Win2003: Nic1: 192.168.1.10 255.255.255.0 192.168.1.1, Nic2: 192.168.2.1 255.255.255.0 -no gateway XPvirtual pc1: 192.168.2.10 255.255.255.0 192.168.2.1 SBS: Nic1:192.168.1.15 255.255.255.0 192.168.1.1, Nic2:192.168.3.1 255.255.255.0 -no gateway XPvirtual pc2:192.168.3.10 255.255.255.0 192.168.3.1 |
| | Re: Routing problems with Virtual PC "Drake96" <Drake96@xxxxxx> wrote in message news:1837968D-C0E4-4018-BA72-41F190CEB10C@xxxxxx Quote: > I have setup 2 test enviornments which consists of Windows 2003 virtual pc > and an XP virtual pc on network 1 and Small Business server virtual pc and > an > XP virtual pc on network 2. The network configurations are as follows. > From > XPvirtual pc1, I can ping both NICs on Win2003 but not the host > (192.168.1.66). From XPvirtual pc2 I can ping the host (192.168.1.66) IP > but > not from the host back. I have setup RRAS the same on both servers but am > getting different results. Ultimately I am looking to test the servers as > routers to/from the 192.168.1.0 network. Any help is appreciated. > Host : 192.168.1.66 255.255.255.0 192.168.1.1 > Win2003: Nic1: 192.168.1.10 255.255.255.0 192.168.1.1, Nic2: 192.168.2.1 > 255.255.255.0 -no gateway > XPvirtual pc1: 192.168.2.10 255.255.255.0 192.168.2.1 > SBS: Nic1:192.168.1.15 255.255.255.0 192.168.1.1, Nic2:192.168.3.1 > 255.255.255.0 -no gateway > XPvirtual pc2:192.168.3.10 255.255.255.0 192.168.3.1 > any other routing. The networking protocols don't know or care whether you are using vms or virtual networks. Pings in on direction only are almost always caused by firewall problems. Temporarily disable the firewall or modify the firewall settings on the clients to allow ICMP echo. |
| | Re: Routing problems with Virtual PC > Routing with virtual machines and virtual networks is just the same as Quote: > any other routing. The networking protocols don't know or care whether you > are using vms or virtual networks. to be a conflict between the Virtual PC and Outpost network drivers that are installed into the physical driver properties. |
| | Re: Routing problems with Virtual PC Thanks for the reply. I should have provided more information in my origional post. I have no firewalls enabled on any of the virtuals or the host box. I have also tried creating static routes, that did not resolve the problem either. The host is a laptop with a wireless nic and the built in nic. I am using a loopback adapter on the built in nic (as the internal network connection). At first, I tried using the local only option for the xp vm's and the internal nic of the servers but that did not work either. I have tried bridging the network connections without success and changed the binding order for the NICs. At this point I am just grasping at anything I can think of. I have never used windows as a router before, but it does not look to be difficult. I have verified the steps from a number of sources on the net. Any additional help is appreciated. "Bill Grant" wrote: Quote: > > > "Drake96" <Drake96@xxxxxx> wrote in message > news:1837968D-C0E4-4018-BA72-41F190CEB10C@xxxxxx Quote: > > I have setup 2 test enviornments which consists of Windows 2003 virtual pc > > and an XP virtual pc on network 1 and Small Business server virtual pc and > > an > > XP virtual pc on network 2. The network configurations are as follows. > > From > > XPvirtual pc1, I can ping both NICs on Win2003 but not the host > > (192.168.1.66). From XPvirtual pc2 I can ping the host (192.168.1.66) IP > > but > > not from the host back. I have setup RRAS the same on both servers but am > > getting different results. Ultimately I am looking to test the servers as > > routers to/from the 192.168.1.0 network. Any help is appreciated. > > Host : 192.168.1.66 255.255.255.0 192.168.1.1 > > Win2003: Nic1: 192.168.1.10 255.255.255.0 192.168.1.1, Nic2: 192.168.2.1 > > 255.255.255.0 -no gateway > > XPvirtual pc1: 192.168.2.10 255.255.255.0 192.168.2.1 > > SBS: Nic1:192.168.1.15 255.255.255.0 192.168.1.1, Nic2:192.168.3.1 > > 255.255.255.0 -no gateway > > XPvirtual pc2:192.168.3.10 255.255.255.0 192.168.3.1 > > > Routing with virtual machines and virtual networks is just the same as > any other routing. The networking protocols don't know or care whether you > are using vms or virtual networks. > > Pings in on direction only are almost always caused by firewall problems. > Temporarily disable the firewall or modify the firewall settings on the > clients to allow ICMP echo. > > |
| | Re: Routing problems with Virtual PC If you can ping in one direction, there is no point in changing any routes. When you ping, the initial message is sent to the target machine using the routes that are on the initiating machine. The reply is sent using the routes which are on the target machine. If you get a ping reply, the routes on both machines are correct. That is why ping is used to check network connectivity. If you can ping in one direction and not the other, the problem is not the basic routing. It is something blocking the target machine from responding to an ICMP echo request. With XP/Vista hosts, this is usually the built-in Windows firewall. "Drake96" <drake96@xxxxxx> wrote in message news:E4B54F3B-1A20-4E75-B0A8-F9A4136B32CF@xxxxxx Quote: > Thanks for the reply. I should have provided more information in my > origional > post. I have no firewalls enabled on any of the virtuals or the host box. > I > have also tried creating static routes, that did not resolve the problem > either. The host is a laptop with a wireless nic and the built in nic. I > am > using a loopback adapter on the built in nic (as the internal network > connection). At first, I tried using the local only option for the xp vm's > and the internal nic of the servers but that did not work either. I have > tried bridging the network connections without success and changed the > binding order for the NICs. At this point I am just grasping at anything I > can think of. I have never used windows as a router before, but it does > not > look to be difficult. I have verified the steps from a number of sources > on > the net. Any additional help is appreciated. > > "Bill Grant" wrote: > Quote: >> >> >> "Drake96" <Drake96@xxxxxx> wrote in message >> news:1837968D-C0E4-4018-BA72-41F190CEB10C@xxxxxx Quote: >> > I have setup 2 test enviornments which consists of Windows 2003 virtual >> > pc >> > and an XP virtual pc on network 1 and Small Business server virtual pc >> > and >> > an >> > XP virtual pc on network 2. The network configurations are as follows. >> > From >> > XPvirtual pc1, I can ping both NICs on Win2003 but not the host >> > (192.168.1.66). From XPvirtual pc2 I can ping the host (192.168.1.66) >> > IP >> > but >> > not from the host back. I have setup RRAS the same on both servers but >> > am >> > getting different results. Ultimately I am looking to test the servers >> > as >> > routers to/from the 192.168.1.0 network. Any help is appreciated. >> > Host : 192.168.1.66 255.255.255.0 192.168.1.1 >> > Win2003: Nic1: 192.168.1.10 255.255.255.0 192.168.1.1, Nic2: >> > 192.168.2.1 >> > 255.255.255.0 -no gateway >> > XPvirtual pc1: 192.168.2.10 255.255.255.0 192.168.2.1 >> > SBS: Nic1:192.168.1.15 255.255.255.0 192.168.1.1, Nic2:192.168.3.1 >> > 255.255.255.0 -no gateway >> > XPvirtual pc2:192.168.3.10 255.255.255.0 192.168.3.1 >> > >> Routing with virtual machines and virtual networks is just the same as >> any other routing. The networking protocols don't know or care whether >> you >> are using vms or virtual networks. >> >> Pings in on direction only are almost always caused by firewall >> problems. >> Temporarily disable the firewall or modify the firewall settings on the >> clients to allow ICMP echo. >> >> |
| | #6 (permalink) |
| | Re: Routing problems with Virtual PC Thanks for the reply. I should have provided more information in my origional post. I have no firewalls enabled on any of the virtuals or the host box. I have also tried creating static routes, that did not resolve the problem either. The host is a laptop with a wireless nic and the built in nic. I am using a loopback adapter on the built in nic (as the internal network connection). At first, I tried using the local only option for the xp vm's and the internal nic of the servers but that did not work either. I have tried bridging the network connections without success and changed the binding order for the NICs. At this point I am just grasping at anything I can think of. I have never used windows as a router before, but it does not look to be difficult. I have verified the steps from a number of sources on the net. Any additional help is appreciated. "Bill Grant" wrote: Quote: > If you can ping in one direction, there is no point in changing any > routes. > > When you ping, the initial message is sent to the target machine using > the routes that are on the initiating machine. The reply is sent using the > routes which are on the target machine. If you get a ping reply, the routes > on both machines are correct. That is why ping is used to check network > connectivity. > > If you can ping in one direction and not the other, the problem is not > the basic routing. It is something blocking the target machine from > responding to an ICMP echo request. With XP/Vista hosts, this is usually the > built-in Windows firewall. > > "Drake96" <drake96@xxxxxx> wrote in message > news:E4B54F3B-1A20-4E75-B0A8-F9A4136B32CF@xxxxxx Quote: > > Thanks for the reply. I should have provided more information in my > > origional > > post. I have no firewalls enabled on any of the virtuals or the host box. > > I > > have also tried creating static routes, that did not resolve the problem > > either. The host is a laptop with a wireless nic and the built in nic. I > > am > > using a loopback adapter on the built in nic (as the internal network > > connection). At first, I tried using the local only option for the xp vm's > > and the internal nic of the servers but that did not work either. I have > > tried bridging the network connections without success and changed the > > binding order for the NICs. At this point I am just grasping at anything I > > can think of. I have never used windows as a router before, but it does > > not > > look to be difficult. I have verified the steps from a number of sources > > on > > the net. Any additional help is appreciated. > > > > "Bill Grant" wrote: > > Quote: > >> > >> > >> "Drake96" <Drake96@xxxxxx> wrote in message > >> news:1837968D-C0E4-4018-BA72-41F190CEB10C@xxxxxx > >> > I have setup 2 test enviornments which consists of Windows 2003 virtual > >> > pc > >> > and an XP virtual pc on network 1 and Small Business server virtual pc > >> > and > >> > an > >> > XP virtual pc on network 2. The network configurations are as follows. > >> > From > >> > XPvirtual pc1, I can ping both NICs on Win2003 but not the host > >> > (192.168.1.66). From XPvirtual pc2 I can ping the host (192.168.1.66) > >> > IP > >> > but > >> > not from the host back. I have setup RRAS the same on both servers but > >> > am > >> > getting different results. Ultimately I am looking to test the servers > >> > as > >> > routers to/from the 192.168.1.0 network. Any help is appreciated. > >> > Host : 192.168.1.66 255.255.255.0 192.168.1.1 > >> > Win2003: Nic1: 192.168.1.10 255.255.255.0 192.168.1.1, Nic2: > >> > 192.168.2.1 > >> > 255.255.255.0 -no gateway > >> > XPvirtual pc1: 192.168.2.10 255.255.255.0 192.168.2.1 > >> > SBS: Nic1:192.168.1.15 255.255.255.0 192.168.1.1, Nic2:192.168.3.1 > >> > 255.255.255.0 -no gateway > >> > XPvirtual pc2:192.168.3.10 255.255.255.0 192.168.3.1 > >> > > >> > >> Routing with virtual machines and virtual networks is just the same as > >> any other routing. The networking protocols don't know or care whether > >> you > >> are using vms or virtual networks. > >> > >> Pings in on direction only are almost always caused by firewall > >> problems. > >> Temporarily disable the firewall or modify the firewall settings on the > >> clients to allow ICMP echo. > >> > >> |
| | #7 (permalink) |
| | Re: Routing problems with Virtual PC > Thanks for the reply. Quote: > Any additional help is appreciated. When getting into such problems I normally use a program dedicated for such problems, and one program I have used with success is MegaPing where I scan the whole network. You also could try "ipconfig" and "route print" in a command prompt, which can tell you a lot about the network. |
| | #8 (permalink) |
| | Re: Routing problems with Virtual PC "drake96" <Drake96@xxxxxx> wrote in message news:358026C2-B660-4682-8DFA-A6955C8D0F2D@xxxxxx Quote: > Thanks for the reply. I should have provided more information in my > origional > post. I have no firewalls enabled on any of the virtuals or the host box. > I > have also tried creating static routes, that did not resolve the problem > either. The host is a laptop with a wireless nic and the built in nic. I > am > using a loopback adapter on the built in nic (as the internal network > connection). At first, I tried using the local only option for the xp vm's > and the internal nic of the servers but that did not work either. I have > tried bridging the network connections without success and changed the > binding order for the NICs. At this point I am just grasping at anything I > can think of. I have never used windows as a router before, but it does > not > look to be difficult. I have verified the steps from a number of sources > on > the net. Any additional help is appreciated. > > to use normal networking tools. RRAS works fine as a router whether it is running in a physical or virtual machine. If you rally can't sort it out you should post in the networking newsgroup. It rally has nothing to do with VPC. |
| | #9 (permalink) |
| | Re: Routing problems with Virtual PC "Bill Grant" <not.available@xxxxxx> wrote in message news:OBC42XArJHA.5912@xxxxxx Quote: > > > "drake96" <Drake96@xxxxxx> wrote in message > news:358026C2-B660-4682-8DFA-A6955C8D0F2D@xxxxxx Quote: >> Thanks for the reply. I should have provided more information in my >> origional >> post. I have no firewalls enabled on any of the virtuals or the host box. >> I >> have also tried creating static routes, that did not resolve the problem >> either. The host is a laptop with a wireless nic and the built in nic. I >> am >> using a loopback adapter on the built in nic (as the internal network >> connection). At first, I tried using the local only option for the xp >> vm's >> and the internal nic of the servers but that did not work either. I have >> tried bridging the network connections without success and changed the >> binding order for the NICs. At this point I am just grasping at anything >> I >> can think of. I have never used windows as a router before, but it does >> not >> look to be difficult. I have verified the steps from a number of sources >> on >> the net. Any additional help is appreciated. >> >> > Ping is not the best tool to use for a situation like this. You will nee > to use normal networking tools. > > > RRAS works fine as a router whether it is running in a physical or > virtual machine. If you rally can't sort it out you should post in the > networking newsgroup. It rally has nothing to do with VPC. |
| Problems with setting up Virtual Machine | Virtual PC | |||
| Problems installing MS Virtual PC 2007 | Virtual PC | |||
| microsoft virtual PC problems | Software | |||
| Re: New 64 Bit Virtual Machine Problems | Virtual Server | |||
| problems w/ Virtual Server & PowerShell | PowerShell | |||
