| | Virtual PC not starting I have just installed Virtual PC 2007 SP1 for Vista 32 bit version, and I have no idea how i can "open" the programm. The programm doesnt appear in my programm list, and yes Im kinda dumb, but its still wont work... |
| | Re: Virtual PC not starting "screenfun2312" <screenfun2312@xxxxxx> wrote in message news:58828D95-1B37-46A0-802A-D5FD6D84BE7E@xxxxxx Quote: > I have just installed Virtual PC 2007 SP1 for Vista 32 bit version, and I > have no idea how I can "open" the program. > > The program doesn't appear in my program list Virtual PC". Assuming you chose the default installation folder, you should be able to find the application in: C:\Program Files\Microsoft Virtual PC, unless you accidentally installed the version for 32-bit Windows on a 64-bit version of Windows. In that folder, there should be a file called Virtual PC.exe - if there isn't, then the installation failed. If there is, this should launch VPC. Assuming it does, simply create a shortcut to it on your Programs menu. -- Mark Rae ASP.NET MVP http://www.markrae.net |
