| | Problem Installing OS iv been trying to install an os onto a VPC but each time i try it gets so far as the install screen and then restarts my physical computer iv only been able to succesfully install MSDOS 7.01 but it does the same during start-up what can i do to keep this from happening?? Thanks. |
| | Re: Problem Installing OS On Sun, 29 Mar 2009 05:12:07 -0700, Mr. Alexx Seven <MrAlexxSeven@xxxxxx> wrote: Quote: >iv been trying to install an os onto a VPC but each time i try it gets so far >as the install screen and then restarts my physical computer > >iv only been able to succesfully install MSDOS 7.01 but it does the same >during start-up > >what can i do to keep this from happening?? > >Thanks. If this resolves the issue, the problem is likely a poor hardware virtualization implementation in the BIOS, looke for an update from the MB vendor. You can also try updating your video and NIC drivers. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | Re: Problem Installing OS Thanks, I Did That And It Stoped The Short Crash Before It Restarted My Computer, And I Also Found That Setting The Allowed Screen Resolutions To Only Standard Ones Allowed Me To Finish The Installations And Succesfully Run Them "Steve Jain [MVP]" wrote: Quote: > On Sun, 29 Mar 2009 05:12:07 -0700, Mr. Alexx Seven > <MrAlexxSeven@xxxxxx> wrote: > Quote: > >iv been trying to install an os onto a VPC but each time i try it gets so far > >as the install screen and then restarts my physical computer > > > >iv only been able to succesfully install MSDOS 7.01 but it does the same > >during start-up > > > >what can i do to keep this from happening?? > > > >Thanks. > First, try disabling hardware virtualization in VPC (File-->Options) > If this resolves the issue, the problem is likely a poor hardware > virtualization implementation in the BIOS, looke for an update from > the MB vendor. > You can also try updating your video and NIC drivers. > > -- > Cheers, > Steve Jain, Virtual Machine MVP > http://vpc.essjae.com/ > |
| Problem Installing..Problem Event Name PCA2 | Vista installation & setup | |||
| problem after installing sp2 | Vista General | |||
installing XP problem | General Discussion | |||
| Problem installing x64 | Vista installation & setup | |||
| Problem Installing RC1 | Vista installation & setup | |||
