Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Misc Newsgroups > Virtual PC
Vista - Virtual PC 2004 upgrade to 2007 Add an existing virtual machine
04-10-2009   #1 (permalink)
yuksel
Hi Friends,
Virtual PC 2004 on a virtual operating system on my computer. later, Virtual
PC
2004 version of the 2007 'I did upgrade to. Virtual PC 2004 version
the operating system to install, Virtual PC 2007 to try to make import
I got the following message.
"Virtual PC was unable to register this virtual machine configuration file.
The saved state associated with the virtual machine is not compatible with
the current version of Virtual PC"
please help me
04-10-2009   #2 (permalink)
David Wilkinson
Re: Virtual PC 2004 upgrade to 2007 Add an existing virtual machine
yuksel wrote:
Quote:
> Hi Friends,
> PC
yuksel:
It would seem that you should have shut down (not save state) the guest in VPC
2004 before trying to open it in VPC 2007.
Maybe you have to reinstall VPC 2004 and do this.
David Wilkinson
Visual C++ MVP
04-10-2009   #3 (permalink)
Robert Comer
You didn't shut the VM's down before the upgrade. There's two things
you can do, one being to uninstall VPC 2007, reinstall VPC 2004, shut
down all the VM's, then upgrade to VPC 2007 again. The other thing
you can do if you don't need the saved state of the VM's, is to delete
the <machine name>.vsv files.
Bob Comer
On Fri, 10 Apr 2009 02:49:02 -0700, yuksel
<yuksel@xxxxxx> wrote:
Quote:
>Hi Friends,
>PC
>please help me
 Virtual PC 2004 upgrade to 2007 Add an existing virtual machine problems?
Similar topics to: Virtual PC 2004 upgrade to 2007 Add an existing virtual machine
Virtual PC 2007 - Install Virtual Machine Additions Tutorials
Virtual PC 2007 - Create New Virtual Machine Tutorials
Virtual PC 2004 vs 2007 Vista General
Re: Virtual PC 2004 vs 2007 Vista General
Installation failures on Virtual PC 2004 and Virtual PC 2007 Vista installation & setup
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
