| | virtual machine 2007 network problem Hello, everybody, recently I`ve got new HP machine with vista business 32 bit version the noborard realtec nic "Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0)" is inclooded. after installing ms vpc 2007 sp1 there is an unknown device in my devices list with no driver for it. the ms vpc 2007 sp1 says that vpc will work with out lan support due the error loading virtual pc network drivers the other hp works with ms vpc 2007 sp1 ok with intel 10/100 nic does my pc nic hw can compromise the vpc work? can anybody coment on this? with best, Janis Briedis |
| | Re: virtual machine 2007 network problem On Sun, 12 Apr 2009 14:46:00 -0700, Janis Briedis <Janis Briedis@xxxxxx> wrote: Quote: >Hello, everybody, > >recently I`ve got new HP machine with vista business 32 bit version >the noborard realtec nic "Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit >Ethernet NIC (NDIS 6.0)" is inclooded. > >after installing ms vpc 2007 sp1 >there is an unknown device in my devices list with no driver for it. >the ms vpc 2007 sp1 says that vpc will work with out lan support >due the error loading virtual pc network drivers > >the other hp works with ms vpc 2007 sp1 ok with intel 10/100 nic > >does my pc nic hw can compromise the vpc work? > >can anybody coment on this? > If not then I suggest you do this first because it is rather common that PC:s are delivered with older versions of NIC drivers and these typically do not work with the VPC network service. The effect is that you get no networking in your guests... -- Bo Berglund (Sweden) |
| Virtual PC 2007 - Install Virtual Machine Additions | Tutorials | |||
| Virtual PC 2007 - Create New Virtual Machine | Tutorials | |||
| error: Virtual PC could not open the Virtual Machine Network Servicesdriver | Virtual PC | |||
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
