| | Virtual PC 2007 disables the ability to Wake over LAN Hello, I've recently come across a problem where Wake on LAN (WoL) hasn't worked on my Vista Ultimate X64 machine. After spending weeks troubleshooting and researching, I came across one small post somewhere that mentioned Virtual PC was causing the error. I uninstalled Virtual PC and immediately following, WoL has worked, flawlessly. I had kept the default settings, and it's possible that changing them could resolve the issue. However, I've neither the time nor patience to try different combination's. Regardless, I'd assume that this is an undesirable side effect, no matter what the settings are. Does anyone know of a fix to resolve this, and is there anyone from Microsoft that can research this bug and possibly resolve it? Until I find a solution, I'm afraid I can't use Virtual PC 2007. |
| | Re: Virtual PC 2007 disables the ability to Wake over LAN I imagine that this is a characteristic of your LAN card or motherboard. If you enable the LAN card in VPC, VPC has to change the configuration of your real LAN card to a debug mode in order to capture the LAN traffic for the Virtual session. Doing this tells the card not to analyse LAN traffic, which makes it impossible for the card to recognise WoL packets, and I imagine that this disables the WoL mode for the card. There is unlikely to be anything VPC can do about the behaviour of your LAN card or mother board. Technically it should be possible to build a LAN card that continues to analyse traffic for WoL packets when in promiscuous mode, but I haven't seen that specified: it would not have been a common requirement. However, if you need a network connection for your VPC, you can add a second LAN card to your host, and tell VPC to use that, and not use the LAN card or motherboard where you need WoL. (david) "Greg St. Louis" <Greg St. Louis@xxxxxx> wrote in message news:6712111B-6A9B-4CF6-8722-20189A47A1AB@xxxxxx Quote: > Hello, > > I've recently come across a problem where Wake on LAN (WoL) hasn't worked > on > my Vista Ultimate X64 machine. After spending weeks troubleshooting and > researching, I came across one small post somewhere that mentioned Virtual > PC > was causing the error. > > I uninstalled Virtual PC and immediately following, WoL has worked, > flawlessly. I had kept the default settings, and it's possible that > changing > them could resolve the issue. However, I've neither the time nor patience > to > try different combination's. Regardless, I'd assume that this is an > undesirable side effect, no matter what the settings are. > > Does anyone know of a fix to resolve this, and is there anyone from > Microsoft that can research this bug and possibly resolve it? Until I find > a > solution, I'm afraid I can't use Virtual PC 2007. |
| Virtual PC 2007 - Install Virtual Machine Additions | Tutorials | |||
| Re: Autorun security change disables DVD drive ability to load softwar | Vista security | |||
| Virtual PC 2007 with Windows ME - Where to place virtual disk | Vista General | |||
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Virtual PC 2007 SP1 disables host TCP/IP!? | Virtual PC | |||
