Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Running VGA Test under DOS
Old 05-01-2009   #1 (permalink)
Jack
VGA Test file error.txt
Test 13: Hardware: General Registers
Mode 00h, General -- Input Status 0: IBM=70h Current=00h
Mode 01h, General -- Input Status 0: IBM=70h Current=80h
Mode 02h, General -- Input Status 0: IBM=70h Current=00h
Mode 03h, General -- Input Status 0: IBM=70h Current=00h
Mode 04h, General -- Input Status 0: IBM=70h Current=80h
Mode 05h, General -- Input Status 0: IBM=70h Current=00h
Mode 06h, General -- Input Status 0: IBM=70h Current=00h
Mode 0Dh, General -- Input Status 0: IBM=70h Current=00h
Mode 0Eh, General -- Input Status 0: IBM=70h Current=00h
Mode 10h, General -- Input Status 0: IBM=70h Current=80h
Mode 11h, General -- Input Status 0: IBM=70h Current=00h
Mode 12h, General -- Input Status 0: IBM=70h Current=00h
Mode 13h, General -- Input Status 0: IBM=70h Current=00h
Expected vertical retrace 35-40 times in 1/2 sec; got 210.
Expected vertical interrupt 35-40 times in 1/2 sec; got 0.
Test 14: Hardware: DAC Registers
DAC Status Register reported wrong status after a read.
There were 2 tests that had errors.
http://www.bookcase.com/library/soft...creen.vga.html
Program: vgatest2
I tried this because printmaster wasn't able to run under DOS (VPC2007)
but was okay under DOSBox 0.72
Do I still have a chance to run it? printmaster appears skewed upon
startup....
Thanks in advance
Jack
Old 05-01-2009   #2 (permalink)
ronald.phillips
Re: Running VGA Test under DOS
On May 1, 7:17*am, "Jack" <j...@xxxxxx> wrote:
> Test 13: *Hardware: General Registers
> * Mode 00h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 01h, General -- Input Status 0: IBM=70h * Current=80h
> * Mode 02h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 03h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 04h, General -- Input Status 0: IBM=70h * Current=80h
> * Mode 05h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 06h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 0Dh, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 0Eh, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 10h, General -- Input Status 0: IBM=70h * Current=80h
> * Mode 11h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 12h, General -- Input Status 0: IBM=70h * Current=00h
> * Mode 13h, General -- Input Status 0: IBM=70h * Current=00h
> * Expected vertical retrace 35-40 times in 1/2 sec; got 210.
> * Expected vertical interrupt 35-40 times in 1/2 sec; got 0.
> Test 14: *Hardware: DAC Registers
> * DAC Status Register reported wrong status after a read.
> Program: vgatest2
> but was okay underDOSBox0.72
> startup....
> Thanks in advance
> Jack
If PrintMaster uses VESA you may want to try Univbe and see if that
fixes it.
If DOSBox fits your needs I'd just use that.
Old 05-02-2009   #3 (permalink)
Jack
Hi Ronald,
I'll give it a try.
Thanks a lot
Jack
Old 05-02-2009   #4 (permalink)
Jack
Hi Ronald
Here is the bad news
I tried out all settings... PrintMaster start menu is still torn up... Any
other tricks?
Thanks
Jack
Errors while run DTM Test USB Address Description Test PowerShell
How to test file-filter-driver in Driver Test Manager(DTM)? Vista General
How to test file-filter-driver in Driver Test Manager(DTM)? Vista hardware & devices
