Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - RE: Running a virutal CE machine
Old 05-09-2009   #1 (permalink)
Anonymous
Quote:
> Has anyone run a CE virtual machine using Virtual PC2007 with Vista? I am
> developing for Windows CE 5.0. with XP I can use the CE Emulator but vista
> doesn't seem to allow the Emulator to work so I thought I would use the
> Virutal PC, but I don't know how to get CE loaded with it.
It can be done. Uses DOS to load a WinCE x86 bin image. VHDs are provided at http://www.hpcfactor.com/support/cesd/s/0119.asp. They should work with Virtual PC 2007 too.
Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com
RE: Running a virutal CE machine Virtual PC
Having problems running a program on my new machine General Discussion
Machine can't be seen while BFE is running Vista networking & sharing
Running TaxCut on New Vista Machine Vista General
License for Vista - running one copy on more than one machine at h Vista General
