| | How to know vPC 2007 base machine ip Hi, After login to the VPC2007 using RDP.How can i know the base machine ip on where i have installed this vpc 2007. |
| | Re: How to know vPC 2007 base machine ip I presume you mean that you have logged into the virtual machine. VPC2007 is the name of the application. Why would you need to know the IP of the host? Doesn't it show up in Network Places (or whatever it is called in the OS you are using)? "Admin" <admin@xxxxxx> wrote in message news:Ocjeqcs0JHA.4880@xxxxxx Quote: > Hi, > After login to the VPC2007 using RDP.How can i know the base machine ip on > where i have installed this vpc 2007. > |
| | Re: How to know vPC 2007 base machine ip On Tue, 12 May 2009 11:31:55 +0530, "Admin" <admin@xxxxxx> wrote: Quote: >Hi, >After login to the VPC2007 using RDP.How can i know the base machine ip on >where i have installed this vpc 2007. > PC on your network. The fact that it is based on a host PC does not matter at all. If I stretch your question a bit: If you log on with RDP to a physical PC (running XP Pro or similar) then how would you go about finding out if the remote PC is actually physically a desktop or a tower model? And if you want to know the color of the chassis? Not simple using just software, right? And also not very useful info either.... What you are really saying is that you would like to know the IP of a computer by logging on with RDP to *another* computer... It makes much more sense if you logged on to the *host* PC with RDP and then checked its IP address. But of course you would not need to because if you sucessfully logged on then you already know its address..... -- Bo Berglund (Sweden) |
| virtual machine 2007 network problem | Virtual PC | |||
| VPC 2007 SP1 - Virtual Machine Additions crashes | Virtual PC | |||
| Re: Stoppin the Autostarting of VM machine under MS virtual pc 2007 | Virtual PC | |||
| Vitrual Machine 2007 | Vista General | |||
