| | Virtual PC 6.0.156.0 vs SP1 Quick question...and thanks for what I hope is a non-time-consuming answer from those in the know here... The 6.0.156.0 version I am running on my XP Pro system...since I want to maximize the Windows 7 RC experience...do I need to uninstall it and go for the more recent one, since I suspect my version is NOT SP1? Thanks for help, as always, Peter -- pg |
| | Re: Virtual PC 6.0.156.0 vs SP1 On Thu, 14 May 2009 10:04:04 -0700, petergoode <petergoode@xxxxxx-microsoft.com> wrote: Quote: >Quick question...and thanks for what I hope is a non-time-consuming answer >from those in the know here... > >The 6.0.156.0 version I am running on my XP Pro system...since I want to >maximize the Windows 7 RC experience...do I need to uninstall it and go for >the more recent one, since I suspect my version is NOT SP1? > >Thanks for help, as always, > >Peter VPC 2007 SP1: 6.0.192.0 the SP1 installer is a full install, not an upgrade, but IIRC, you don't need to uninstall the older version first. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | Re: Virtual PC 6.0.156.0 vs SP1 Thanks for that, I already noted the difference in software numbers, and will install the sp1. I also need to thank you once again for your big file on setting up Virtual Machines on PC's with no floppy drive, I really don't think most people would have figured that out without your help! -- pg "Steve Jain [MVP]" wrote: Quote: > On Thu, 14 May 2009 10:04:04 -0700, petergoode > <petergoode@xxxxxx-microsoft.com> wrote: > Quote: > >Quick question...and thanks for what I hope is a non-time-consuming answer > >from those in the know here... > > > >The 6.0.156.0 version I am running on my XP Pro system...since I want to > >maximize the Windows 7 RC experience...do I need to uninstall it and go for > >the more recent one, since I suspect my version is NOT SP1? > > > >Thanks for help, as always, > > > >Peter > VPC 2007: 6.0.156.0 > VPC 2007 SP1: 6.0.192.0 > > the SP1 installer is a full install, not an upgrade, but IIRC, you > don't need to uninstall the older version first. > > -- > Cheers, > Steve Jain, Virtual Machine MVP > http://vpc.essjae.com/ > |
| | Re: Virtual PC 6.0.156.0 vs SP1 On Thu, 14 May 2009 14:38:01 -0700, petergoode <petergoode@xxxxxx-microsoft.com> wrote: Quote: >Thanks for that, I already noted the difference in software numbers, and will >install the sp1. > >I also need to thank you once again for your big file on setting up Virtual >Machines on PC's with no floppy drive, I really don't think most people would >have figured that out without your help! I'm working on updating my site for VPC7, since it no longer has a virtual floppy drive, it makes it difficult to use VFDs for installing Win98. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | Re: Virtual PC 6.0.156.0 vs SP1 Steve Jain [MVP] wrote: Quote: > On Thu, 14 May 2009 10:04:04 -0700, petergoode > <petergoode@xxxxxx-microsoft.com> wrote: > Quote: >> Quick question...and thanks for what I hope is a non-time-consuming answer >>from those in the know here... >> The 6.0.156.0 version I am running on my XP Pro system...since I want to >> maximize the Windows 7 RC experience...do I need to uninstall it and go for >> the more recent one, since I suspect my version is NOT SP1? >> >> Thanks for help, as always, >> >> Peter > VPC 2007: 6.0.156.0 > VPC 2007 SP1: 6.0.192.0 > > the SP1 installer is a full install, not an upgrade, but IIRC, you > don't need to uninstall the older version first. > |
| | #6 (permalink) |
| | Re: Virtual PC 6.0.156.0 vs SP1 http://www.microsoft.com/downloads/d...displaylang=en At the bottom it lets you download either the 32-bit or the 64-bit versions. -- Bob Comer On Fri, 15 May 2009 09:42:04 -0400, Hipupchuck <hipupchuck@xxxxxx> wrote: Quote: >Steve Jain [MVP] wrote: Quote: >> On Thu, 14 May 2009 10:04:04 -0700, petergoode >> <petergoode@xxxxxx-microsoft.com> wrote: >> Quote: >>> Quick question...and thanks for what I hope is a non-time-consuming answer >>>from those in the know here... >>> The 6.0.156.0 version I am running on my XP Pro system...since I want to >>> maximize the Windows 7 RC experience...do I need to uninstall it and go for >>> the more recent one, since I suspect my version is NOT SP1? >>> >>> Thanks for help, as always, >>> >>> Peter >> VPC 2007: 6.0.156.0 >> VPC 2007 SP1: 6.0.192.0 >> >> the SP1 installer is a full install, not an upgrade, but IIRC, you >> don't need to uninstall the older version first. >> >I couldn't find the 64 bit version with SP1. |
| | #7 (permalink) |
| | Re: Virtual PC 6.0.156.0 vs SP1 "Hipupchuck" <hipupchuck@xxxxxx> wrote in message news:R5KdncZGRNiw7JDXnZ2dnUVZ_jVi4p2d@xxxxxx Quote: > I couldn't find the 64 bit version with SP1. N.B. http://vpc.visualwin.com/ngfaq.aspx#18 -- Mark Rae ASP.NET MVP http://www.markrae.net |
